Twenty Two clutch
Twenty Two clutch
thomas84
Send a private message to thomas84
I had the clutch on my twenty two relined and was wondering how tight to tourque the clutch springs that hold the pressure plate on? Thanks 👋
Wed, Nov 10, 2010 9:08 AM
thomas84
Any help would be appreciated, I just wanted to make sure I did it right the first time.
Fri, Nov 12, 2010 8:35 AM
nw4evr
Send a private message to nw4evr
Reply to thomas84:
I also am curious about this, I will be the 22 clutch re-assembly stage shortly, and i still haven't been able to find the 1179 book for the 10 15 and small 20. And have been searching for one for quite a while. Someone out there must know.
R2 5E 3542 SP, 22 2F, 22 1J
Fri, Nov 12, 2010 9:02 AM
Reply to nw4evr:
I have never worked on one of these units so I can only suggest the following seeing no-one else has responded as yet, I will speak in general terms for this type clutch as it is shown in the cutaway drawing in my Parts Book.
The Parts Book cutaways are usually exactly as the parts are machined by shape and positioned in the assembly. The Clutch cutaway shows the nuts being set at about 1 full thread below the top face of the studs.
Provided the clutch stack height/thickness is somewhere near spec. the clutch should have enough freeplay in the spring coils to release correctly/fully and also not slip when operating at full load.
The only other thing to consider is that if the spring tensions vary from each other you may have to tighten some more than others to get the clutch to disengage squarely and therefore engage smoothly without shudder.
Others with experience of the 22 clutch may have more to add or correct me if I have erred!!!
If it were my clutch the above is how I would address the problem, and then see how it operated.
Hope this helps.
Fri, Nov 12, 2010 11:49 AM
bruce oz
Thank you received: 10
Reply to edb:
Hope this helps.
hello ,i have looked at the books for 10-15- both 20's and the manuals say count the turn when you undo them ,not much help if you can not remember :jaw:how many turns you undone then ,.bruce oz
Fri, Nov 12, 2010 3:21 PM
thomas84
Reply to bruce oz:
Thanks you guys, I will Try to get it back together this weekend.👋
Sat, Nov 13, 2010 9:11 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
