ACMOC main sitemember log in
Showing 1 to 10 of 22 results
chugwater crawlers
Anyone unable to log in to the members section on the acmoc site?
It no longer recognized my user name and/or password.
I did email the administrator.
Mon, Nov 1, 2010 2:22 AM
SpragueM
I have not been able to log on for several days. Just tells me" not recognized user name" when I look for password, obviously at the same time I am able to log in here.
Matt
Mon, Nov 1, 2010 3:21 AM
Rodten
Reply to SpragueM:
Matt
same problem here. I was able after about the 5 try yesterday but same problem today even after hitting the remember me tab.
Mon, Nov 1, 2010 3:39 AM
OldNuc
Send a private message to OldNuc
Reply to Rodten:
Use the exact USERNAME and PASSWORD you are using for the BBS. Works fine.
Mon, Nov 1, 2010 4:26 AM
chugwater crawlers
Reply to OldNuc:
I have tried that it does not work for me.
Mon, Nov 1, 2010 4:35 AM
josh
Thank you received: 6
Reply to chugwater crawlers:
I can log in, but now I have to do it every time I visit the board, it will not remember me.
Josh
Mon, Nov 1, 2010 4:47 AM
D4Jim
Thank you received: 12
Reply to josh:
Josh
The site is messed up as I had to log in twice just to post this. It now shows my handle D4Jim at the top but when I go to another section I have to log in all over again.
Same problem they had a couple years ago.
Kind of aggravating but I am sure they will get it fixed.
Cats Forever
Mon, Nov 1, 2010 5:19 AM
B4D2
Reply to D4Jim:
Megan is working the bugs out of the system. Amongst other updates, we have made some changes to allow users to access both parts of the website with one user name and password. She is aware of the concerns and is addressing them.
Mon, Nov 1, 2010 6:29 AM
Rodten
Reply to B4D2:
So with the changes to the web site the same password can be used on the Members site and the Forum. Is there a way to keep non members out of the member site. Or is this area now open to members and non members?
Mon, Nov 1, 2010 10:09 AM
adco-d12
Send a private message to adco-d12
Reply to Rodten:
If you're not able to log in to both the main website and the bulletin board using the same info, please send me a note. Also, if you're an ACMOC member but can't access the Members area of the main website with your usual login, please send me a note. There are a number of cases where email addresses were missing in the ACMOC member database, so your account may not be connected properly. Just let me know and I'll get it straightened out.
Rodten: Yes, the Members area is still restricted to ACMOC Members only, but non-members can still log in to the site, for example to place orders from the store.
Bulletin board problems? Email your questions to [email protected]
(...I can't tell a tractor from a lawnmower, so we're even.) :noidea:
Mon, Nov 1, 2010 10:12 AM
cojhl2
Reply to adco-d12:
[quote="adco"]
Rodten: Yes, the Members area is still restricted to ACMOC Members only, but non-members can still log in to the site, for example to place orders from the store.[/quote]
Hmm,, so they aren't restricted?
Mon, Nov 1, 2010 10:39 AM
