Where 2 buy pad bolts???
Showing 1 to 9 of 9 results
NIK O.
Send a private message to NIK O.
Rd4 4g, 1/2 in. Changing all to new pads. Am short one pad, would buy good one. She will not be used daily. Old lock washers still have spring, reuse, or or new ones same quality.?? If i had strength #, could order from local nut & bolt. Thanx, be blessed & be thankful, nik
Sun, Oct 24, 2010 2:22 AM
Steve A
Go to a track shop and order a Hardware Kit, still not cheap but your talking 60 +pounds of steel
Sun, Oct 24, 2010 2:54 AM
Reply to Steve A:
According to my parts book the 4G used regular hex head cap screw #S-1584 which is a 1/2 in. x 20 tpi x 1-3/4 in. length.
The nuts are a #1B4432 high head fine thread.
The washers a #3B4508
This is all common hardware, available in grade 8 (150,000 psi).
Available from outfits like McMaster or MSC.
Apparently they didn't use the fancy head version and 160,000 psi strength they use now.
Sun, Oct 24, 2010 4:27 AM
NIK O.
O.m., sir, xactly what i needed. U r one of many blessings on this site. Nik, 1921 nichols & shepard 25-85 single, cat & d-44oo stationary.
Sun, Oct 24, 2010 6:30 AM
SSsssteamer
Send a private message to SSsssteamer
Reply to NIK O.:
When I did my D8 14A, Our local Cat shop "NC Machinery" sold me the correct pad bolts for about half of what anyone else could do. Unless your RD 4 pad polts are no longer stocked by your local Cat Dealer, I wouldn't shop for pad bolts anywhere else.
Sun, Oct 24, 2010 7:30 AM
Frank Fox
Send a private message to Frank Fox
Reply to SSsssteamer:
Hard to beat "CAT" bolts at any price.
Frank👍
Sun, Oct 24, 2010 9:57 AM
Reply to Frank Fox:
Frank👍
The Cat bolts will probably have the slightly higher heads and hopefully known quality control. Can't say that I use them except is some critical applications. If your concerned you might try moving to a commercial grade 9 (180,000 psi) which also has the taller head.
Sun, Oct 24, 2010 11:43 AM
Nik,
Are you looking for a pad also?
"Am short one pad, would buy good one. She will not be used daily."
What width and length?
As far as the bolts, I was under the impression that not only do they have a taller head but are shouldered where they go through the pad and the rail?
Jeff
Sun, Oct 24, 2010 6:58 PM
W. SMITH
Send a private message to W. SMITH
Reply to drujinin:
Nik,
Jeff
NIK O. I would buy a track bolt only, from Caterpillar if possible. I once saw someone put grade 8 bolts in instead and the bolt heads started to seperate from the bolt shaft, I could see the top of the head caving in. At that point I realized that Caterpillar made track bolts with the very tall and rounded bolt head for a GOOD REASON. This happened on the master link of a D7G track but after seeing the results I still will not cut corners on any track bolts. W. SMITH
Sun, Oct 24, 2010 7:36 PM
oldtanker
Send a private message to oldtanker
Reply to W. SMITH:
On a couple of other brand crawler pages there has been a lot of discussion about pad bolts. Seems most of the problems guys are having is with "box" store bolts. Some are claiming that the bolts are not up to thier ratings.....I.E.....grade 8 really equals grade 5. I know our local "bolt" store carries stuff that comes from China. Prices are good but if they don't hold.......
Rick
Sun, Oct 24, 2010 9:53 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
