Cat Classic Parts vs. Standard Cat Parts
Showing 1 to 9 of 9 results
Aphonopelma
Send a private message to Aphonopelma
Hi All,
As I continue to work out all the bugs on my 951C I routinely have the option on major components to order "Cat Classic Parts" instead of the original (if available) Cat parts. The classic parts tend to be 1/2 to 1/3 the cost but only have a 6 month warranty. Even the sales people tell you they won't last as long as original parts. What are your experiences using these parts, do they hold up well and do you feel you got your moneys worth? Thanks for your input.
Scott
1975 951C
Thu, Oct 7, 2010 12:20 AM
rditz
Send a private message to rditz
When I got my 955, i was referred to a local fellow who worked for the CAT dealer. he came out to the house one evening and he told me the that if i needed to order parts to make sure i used the term "classic". he also said that the desk clerks don't always offer this.
the difference is that he said they were the exact same part and came from the same shelf.
so far I have managed to get everything i need through this forum, so i haven't tested the dealer yet.
rod
Thu, Oct 7, 2010 1:25 AM
Mike Walsh
Reply to rditz:
rod
Cat was loosing sales to the aftermarket suppliers so they started selling the aftermarket parts as "classic" parts. Usually they charge a little more than a similar aftermarket part. Hopefully you are paying for quality control and the good parts go to Cat; the balance to everyone else. We've used lots of them and had no major problems. I thought the warranty was the same. If you are buying something that's heat treated, don't expect the same quality as the original. An important issue when dealing with finals and transmissions as tolerances and heat treatment of gears shafts and bearings determines longevity. However, its hard to spend 20K on gears and another 5K on bearings when you're working on something that gets 20 hrs of use a year.
Thu, Oct 7, 2010 8:42 AM
gwhdiesel75
Reply to Mike Walsh:
Mike, from your message, it appears that Cat is not the manufacturer of the classic parts. Since others manufacture the parts, the Cat quality control isn't there. Or am I wrong? gwh
Thu, Oct 7, 2010 8:21 PM
Thank you received: 22
Reply to gwhdiesel75:
Here is what Cat has to say.
http://www.cat.com/cda/layout?m=48662&x=7
Thu, Oct 7, 2010 9:56 PM
d9gdon
I can tell you from my experience that they're not the same part as what Cat makes. I got an alternator pulley for my 120G motor grader in Classic and drove 65 miles to put it on and the damned thing wasn't even machined right. There was a ridge in the hole that wouldn't let it go on the shaft. I had to go all the way back and buy the Cat pulley for $240 dollars (somewhere in that neighborhood) cause I had waited a day for $49 Classic pulley to come in and didn't want to wait another day just to gamble on another one. And I didn't have any way to machine the ridge out of the other one.
I bought a Classic muffler for a 627 scraper and it weighed about half as much as the Cat muffler, but was about a third of the price. I can tell it's not going to last very long, made the wrong choice on that one.
On the other hand, I bought a Classic crankshaft for a 3304 that was about $1000 when Cat wanted $4000 for their new one and I didn't have any trouble with it in four busy years of work. I compared it to the Cat crank before I bought it though.
Classic just isn't the same as the Cat part, and was never intended to be. There's a use for them, but overall it would have to be light use in most cases. Some pieces, like the muffler aren't even as good as other aftermarket brands that are priced similarly.
Thu, Oct 7, 2010 10:44 PM
Mike Walsh
Cat does not manufacture a lot of what they sell. They do however have the ability to impose their standards upon those who manufacture for them. My experience is the same as d9gdon; hit and miss. I'm a pessimist so if Cat begins to resell more and more parts from China rather than Italy and Turkey, I believe the quality is going to go down.
Fri, Oct 8, 2010 5:42 AM
bob
Send a private message to bob
Reply to d9gdon:
They are aftermarket blessed by Peoria. I would always recomend good used Cat Parts but NEVER Classic Parts. Most are like the alt pully mentioned above. Even if they cover them with warrenty, you still need to do the job over and over untill you get a good one.
Later Bob
Fri, Oct 8, 2010 5:49 AM
Reply to bob:
Later Bob
Reminds me of the typical junk yard guarantee....If it doesn't work bring it back and we'll give you another one....that doesn't work either.
Fri, Oct 8, 2010 6:24 AM
Well i think it also involves the cost of the part. I recently replaced a track recoil spring---Cat wanted $896 for a new one and i bought a Chinese one for $190 plus $125 to have the bolt changed and the spring compressed. Say 3 hr of my time to take out and replace. If i had to do it twice I would still be way ahead. :dance:
Fri, Oct 8, 2010 7:04 AM
