Flushing cooling system
raklet
Send a private message to raklet
I was reading my SRM for the D318 Engine, and it said that to flush the cooling system one should fill drain the coolant and refill the system with a mixture of muriatic acid, water, and antifreeze then operate for 3 hours. Drain and refill with water and antifreeze.
Is this still the recommend procedure, or has modern technology produced other substances that are better for cleaning out the system?
Fri, Sep 24, 2010 9:48 AM
Get something from the store. I have used the muriatic acid though. Didn't help on the overheating much, but did soften up the scale so it was easier to rod out the radiator.
If you're just doing it as a preventative, I would use one of the commercial radiator flushes. Most are citric acid/citrate based these days. They are safe for people and the radiator and are reasonably effective, though you may want to allow a little longer run time than the muriatic acid recomendation. You could take out the drain valve plug or unscrew the temperature gauge probe to gauge when you have removed all the scale.
Fri, Sep 24, 2010 10:20 AM
raklet
Thanks. I don't have to do it to the block or head, because I've just finished rebuilding it and everything has either been hot tanked or washed with solvent under pressure, but there is still the radiator to think about. How do I clean that by itself so I don't run all that dirty junk through my nice clean engine?
Fri, Sep 24, 2010 11:03 AM
Thank you received: 7
Reply to raklet:
Take the radiator apart and rod it out.Just be careful with all the bolts,don't know if I am just lucky or what but a little heat does wonders.I have used brass brazing rod on the most plugged tubes,finished with a1/8 by 3/4 piece of aluminum.The gaskets were still available from Cat last year.Ray
Fri, Sep 24, 2010 9:05 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
