Not to my knowledge has the main engine oil been used by the pup motor on a D2. You might want to check your main engine for signs of oil in the coolant since they share the same cooling system. Could have a crack in the pup block some where.😞😞
Sorry Tim misread the model of machine. will try to get back to you with more pertenent info. Kevin
