Initial Valve Clearance Setting
raklet
Send a private message to raklet
I'm putting my D318 engine back together after having the head off. The book says to set valve clearance (hot). I'm assuming that means after the engine has warmed up. But, what should I set it to initially (cold) until I have a chance to turn the engine over and warm it up?
Thu, Aug 26, 2010 9:30 AM
smitrotterdam
Send a private message to smitrotterdam
My D318 is in a 1953 DW10 . I set the valves at .010" cold. Ran the engine up to 170 degrees and set them again, hot, with the engine running at .010".
Hope that helps.
Thu, Aug 26, 2010 10:12 AM
I would try 0.012" cold as an initial setting. It will be very close when it's hot. In my book, not worth going back through hot, but to each his own.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Thu, Aug 26, 2010 10:34 AM
64farmboy
I set mine @ .012 cold and because I'm anal about stuff I checked when hot and they all were right at .010๐Ÿ‘
Thu, Aug 26, 2010 6:33 PM
