44 hydraulic oil
44 hydraulic oil
64farmboy
Team, What oil should I run in the 44 unit on my D2 5U12142? When I rebuilt it I filled it with Hydraulic oil but I've seen on a thread here where 10 weight is what Cat recommends. Which is the preferred oil?
Dennie
Tue, Aug 24, 2010 6:34 PM
Here are the original specs.
Either engine oil or hydraulic oil is acceptable.
10w oil is equivalent to an ISO 32 hydraulic oil @ 155 ssu.
That being said in my Calif climate and well worn pump I run an ISO 68 hydraulic oil (SAE 20 equiv) @ 325 ssu. It is a little slow to build pressure on cold start up.
I would prefer to run an ISO 46 (SAE 10 equiv)@ 215 ssu but it is not compatible with other systems I run off the pump
Tue, Aug 24, 2010 10:10 PM
64farmboy
OM, thanks for the info, while it gets to -25F here I don't intend to go out into it with my D2. I may be nuts but I'm not crazy. All kidding aside I'll stick with the 10 weight and or hydraulic oil, during the winter months I have the old girl inside in my semiheated shop so if for some reason (pull the log truck out?) I had to take her out she'd be warm anyway.
I'll be tackling that right hand steering clutch this winter as soon as the construction projects slow down
Thanks again😆
Dennie
Wed, Aug 25, 2010 3:13 AM
