Cat Performance Handbook
Showing 1 to 6 of 6 results
7upuller
Can anyone look up in an older performance book and tell me the break out force
of an early model 235(A model) excavator. -glen
Tue, Aug 24, 2010 8:19 AM
d6pete
Send a private message to d6pete
from 1973 perf.book 225w/125 hp. bo.8ft. stick.-22,000lb... bucket 1cu.yd.-25,600 lb.
Tue, Aug 24, 2010 8:47 AM
d6pete
Reply to d6pete:
i am not a jr. mmbr.! looked quick took 225 for 235!!! anyways, bk.#20 .😞 235(64r) only lists cap.@17,300lbs.
Tue, Aug 24, 2010 9:12 AM
Reply to d6pete:
Hi Glen,
I don't deal with these specs very often. Is your break out force same as lifting capacity? I don't see the term breakout force being used in my handbook.
For a 235 w/8ft stick, standard undercarriage I see 27,200 lbs at 15 ft reach and zero bucket hinge pin height.
At -10 ft at 10ft reach it is 28,300 lbs.
Tue, Aug 24, 2010 10:48 AM
Hi Glen,
this should get you there.
Tue, Aug 24, 2010 11:07 AM
Reply to edb:
It's all in what you ask for......
Tue, Aug 24, 2010 11:23 AM
7upuller
Thanks Guys,
The replies are helpful.-glen
Tue, Aug 24, 2010 12:10 PM
