Reply to Mike Meyer:
Sounds like the pinion grinding into gear with the flywheel, then having to hold the gear in place till it starts the main motor. Either clutch is not disengaging properly, or the pinion brake is not working, followed by the latches not holding when engaged? Or is the clutch just not "locking over" when engaged?
I'd flush that starter pinion/ clutch housing with gas or kerosene at least twice to remove all the old crud, then refill to correct level with ATF, then adjust the pilot clutch till it "Snaps Over" and see what happens. If it still misbehaves like my RD4 does because it's all just pretty worn in there, then either pull the pilot motor and fix it, or buy another old Cat to play on. I've found it's usually cheaper to buy another old Cat because one job always leads to another, which leads to another, and another, etc, etc, etc, just ask Zootownjeepguy 😆😆
[quote="Mike Meyer"]Sounds like the pinion grinding into gear with the flywheel, then having to hold the gear in place till it starts the main motor. Either clutch is not disengaging properly, or the pinion brake is not working, followed by the latches not holding when engaged? Or is the clutch just not "locking over" when engaged?
I'd flush that starter pinion/ clutch housing with gas or kerosene at least twice to remove all the old crud, then refill to correct level with ATF, then adjust the pilot clutch till it "Snaps Over" and see what happens. If it still misbehaves like my RD4 does because it's all just pretty worn in there, then either pull the pilot motor and fix it, or buy another old Cat to play on. I've found it's usually cheaper to buy another old Cat because one job always leads to another, which leads to another, and another, etc, etc, etc, just ask Zootownjeepguy 😆😆[/quote]
HEY!!!!!!! I HEARD THAT!!! 👋
Rich Salvaggio
D2 5U9917
