Pics of my 30
Pics of my 30
Showing 1 to 9 of 9 results
Rodten
Here are some pics of the thirty I am trying to free up and get running. It seems that #3 piston is seized (as it is the only one still holding PB blaster and WD 45 that I am spraying in). Any other ideas to free it up with out further teardown. When it was free I did get it to pop but never take off on run, so I hate to tear it down unless nessisary.
Fri, Jul 30, 2010 6:00 AM
Jason 10/D4
Looks like a good winter project don't give up maybe try some gibbs or kroil and maybe heat the jugg a little to make the penetrant work better. Thirties are nice tractors we have two and yours looks to have a cold wheather package on it could it have been a city or state tractor at one time? Jason👍
Fri, Jul 30, 2010 6:37 AM
Rodten
Reply to Jason 10/D4:
yes it has cold weather package. Also the belt pully in back. I went up to WI for this tractor because of the oddity of it. I keep adding PB to the Jugs. I have also but in some break fluid. Just keeping soaken and the waight of the concrete block on the engaged crank. Hopefully it will do the job.
Fri, Jul 30, 2010 7:01 AM
chriscokid
Reply to Rodten:
I have never tried this...... but you could take the plug out on the stuck cylinder and put compressed air into it to force the penetrating fuild down around the piston? Maybe some other guys will have some better advice.
Fri, Jul 30, 2010 7:39 AM
Rodten
Reply to chriscokid:
thanks Erik
That makes since in thoery, I will see what kind of fittings I have tomorrow and give it a try.:doh:
Fri, Jul 30, 2010 10:10 AM
YeLLoIrOn
Send a private message to YeLLoIrOn
Reply to Rodten:
thanks Erik
You can get the hose already made for this at a local auto parts store. I use one to fill the cylinders when changing valve springs on a race engine.
to use the compressed air method to get the penatrent past the rings your going to have to back the rockers on the # 3 cylinder first, I'd just loosen the shaft hold down bolts off and pull the rocker assembly up on 3 and 4. Leave all the plugs out of the rest of the cylinders and put the air to it.
After you do that take and pull the clutch cover on the top of the transmission housing and take a pry bar and pry it in the "OPPOSITE" direction of rotation.
It will probably turn loose.
If you get it loose before you go turnin on it be sure and take the handle end of a hammer and bump all the valve making sure they move up and down freely.
Fri, Jul 30, 2010 11:01 AM
64farmboy
Reply to YeLLoIrOn:
If you can't find one I made one from a sparkplug and a quick disconnect fitting, I broke out the porcelin and welded the fitting into the plug body, I made one for both 14mm & 18mm plugs😆
When I couldn't get my D2 loose I pulled the head and welded up a cradle to attach to the head bolts, I made the cradle just high enough to fit a small bottle jack in. I then machined up a 3.950 diameter aluminum slug to set on the top of the piston. I was able to put light pressure on the piston top with the pistons soaking in PB and she broke loose.
Fri, Jul 30, 2010 5:48 PM
Forcus
Send a private message to Forcus
Reply to 64farmboy:
To get mine loose I soaked it in kroll, MMO, and some other stuff for 6 months but no luck. Ended up taking the head off scraping out between the ring lands and walls (full of crud), then refilling with MMO, etc and lighting on fire. Afterwards took a wood block and small sledge and knocked it a few times. Then was able to turn the engine back and forth by the fan blade. I estimate it had sat 20 years with that cylinder exposed to humidity through an open exhaust valve.
Fri, Jul 30, 2010 10:39 PM
spike
Send a private message to spike
Reply to Forcus:
Are the valves closed ? If so weld grease zert into a old spirk plug fill cylinder with oil put in plug hook up grease pump or grease gun .You can include a pressure gaigue if you are worried . pump away down she goes 5000.00psi .Ido it to old hit miss engines all the time .Spike
Sun, Aug 1, 2010 8:08 AM
Rodten
Reply to spike:
Thanks spike
I have heard this one too but I do not have one welded up yet. It is in the back of my mind.
Sun, Aug 1, 2010 9:17 AM
Price Tractor Pull
Price Tractor Pull
