Fiat-Allis 10C
Fiat-Allis 10C
catd69u
Send a private message to catd69u
I know this is off topic, but a friend of mine has a Fiat-Allis 10c dozer, and we are trying to find out what kind of oil to put in the transmission. If anybody on here knows or can help us, I would greatly appreciate it. Thanks in advance........................Barry Franklin
Sat, Mar 31, 2007 9:15 AM
chugwater crawlers
I'm not an expert, but I have a 14C. The operators manual calls for the following lubricants:
Engine -"EO". EO = 15/40 wt engine oil
Transmission hydraulic system-"EO". EO= 15/40 wt engine oil
Final drives- "MGO". MGO = multi purpose gear oil
Transmission torque converter - "TF". TF = transmission fluid. Says use "ATF type A, Suffix A, or C-3 transmission fluid".
Dozer hydraulic system says one of the followng: "Engine oil MIL-L-210C, API, CD Type C-3 Trans FLuid TO-2 qualified, API, CD".
This is for a 1987 14C with an Iveco engine. Your 10C may be different. Proceed accordingly. The 14C machines would overheat due to radiator plugging. Watch your temp gauge. Good luck!
Sun, Apr 1, 2007 2:14 AM
catd69u
Reply to chugwater crawlers:
Thanks for the reply. I appreciate it.
Barry
Sat, Apr 7, 2007 8:32 PM
Earlcoate Charity Open Day
