5U-D2 Bearings
5U-D2 Bearings
hicrop10
I am looking for my 5U-D2 pony motor,the rod,main bearings and also the ring group.I have price them at Cat and found the rings to be about $10.00 each not to bad,but the mains and rod bearing are around $150 each.Just looking for some after market prices.Thanks Mike Durkin
Fri, Jun 11, 2010 10:54 PM
Sasquatch
Check Hastings for pony rings, I think I remember them having complete sets for around $35 or so.
Sat, Jun 12, 2010 12:30 AM
Mike Meyer
Reply to Sasquatch:
I get a lot of parts from Florin Tractor in California, both genuine and AM, in fact I'm just about to order a heap more today, including the bearings and seals for my final drives on my D2 4U, their prices are very reasonable and service is great, talk to Dana or Judy, or email them as I do. I've found if you ask around a few places you can save yourself thousands on a rebuild, I saved almost a thousand just on the D2 final drive bellow seals.
Mike
Sat, Jun 12, 2010 4:00 AM
jmvmopar
Reply to Mike Meyer:
Mike
Do you know if you have a measurements from your crank? Std or not.
But the bearing numbers I have are
Rod bearing 0.020 3B7938
http://www.machinerytrader.com/list/partsSearch.aspx?PCID=&dlr=&GUID=532a8c6936374d4b8b31d4ecd1700213&Manu=&Mdltxt=&mdlx=Contains&PartNum=3B7938+&btnPartSearch=Search&PST=Starts&fullsearch=
Rod bearing STD. 3B3014
http://www.machinerytrader.com/list/partsSearch.aspx?PCID=&dlr=&GUID=532a8c6936374d4b8b31d4ecd1700213&Manu=&Mdltxt=&mdlx=Contains&btnDismantledSearch=Search&PartNum=3B3014&PST=Starts&fullsearch=
Main Bearing flywheel side 0.020" 4F9416
Main Bearing 0.020" 4F9413
Main Bearing flywheel side STD. 4F9417
http://www.machinerytrader.com/list/partsSearch.aspx?PCID=&dlr=&GUID=532a8c6936374d4b8b31d4ecd1700213&Manu=&Mdltxt=&mdlx=Contains&btnDismantledSearch=Search&PartNum=4f9417&PST=Starts&fullsearch=
Main bearing STD. 4F9414
http://www.machinerytrader.com/list/partsSearch.aspx?PCID=&dlr=&GUID=532a8c6936374d4b8b31d4ecd1700213&Manu=&Mdltxt=&mdlx=Contains&btnDismantledSearch=Search&PartNum=4f9414&PST=Starts&fullsearch=
You could also have the main bearings rebabbitted to your desired size. I had some rod bearings done by Antique Engine Bearing Service in CA. They did a great job and cost was about $95 per bearing with shipping. I bet they could do it cheaper than that for those bearings.
Sat, Jun 12, 2010 10:34 PM
