According to my parts book it says 14 quarts and the 46 unit uses 7 gallons. Quite a differance. Charlie
Charlie, thanks I'll put in 14 and see how she works
Dennie
Ya, my operators book says 3.5 gallons minimum to operate.
Wouldn't you think the level will drop when you fill the hoses and the cylinders? Ya don't want to hurt anything. Charlie
For sure the cyl's and hoses will lower the fill level, I picked up a 5 gallon pail, I'll start with the 14 qts, run it to fill the cyl & hoses then add more oil, once it warms up, I can see into the fill tube, If I can see oil in the fill tube when its warm it should be enough oil in the system.
Dennie
