Steering under load...
Showing 1 to 10 of 11 results
D6c10K
Send a private message to D6c10K
I try not to pull the steering clutches too much when I've got a full blade (D6c), but was wondering how hard it was on the clutches to do so? Seems like it would be ok under light load, but regularly re-engaging a clutch under a heavy load seems like it might cause some trouble. What do you think?
Thu, May 27, 2010 7:18 AM
zip
Send a private message to zip
Your ok have fun with it there made to do that .
Thu, May 27, 2010 7:21 AM
Thank you received: 43
Reply to zip:
When pulling a load as in farming they
Thu, May 27, 2010 9:36 AM
Reply to zip:
When pulling farm equipment they are under load most of the time as you turn.Just be smooth with your turn and not jerky,and don't let the lever fly forward. Ray
Thu, May 27, 2010 9:45 AM
Old 3T lover
Reply to Ray54:
I never liked to see my operators jerking my dozers around and trying to work them in higher gears going forward. I wanted them to push all the dozer would push in low gear, be it brush are dirt. With a "full" load like that it was hard to steer the machine with the steering clutches. If you pulled the steering clutch to release one track, the machine would stall out, spinning one track, not turning or moving the load. I taught them to use the tilt cylinder for minor steering corrections under heavy loads.
There's a time and a place for light loads and speedy operating but slow and steady gets the job done faster with fewer problems and less wear and tear.
Thu, May 27, 2010 5:04 PM
Online
Thank you received: 99
Hi, D6c10K.
Steering a clutch-n-brake steered dozer under blade load is a whole different ball game from steering the same machine under a drawbar load. Firstly, the blade load is further ahead of the tractor than the drawbar load is behind the tractor. Secondly, with a loaded blade on a dozer, you are trying to force the load on the blade sideways against the resistance of the load resting on the ground. (A drawbar load is being dragged around behind the tractor which does not load the tractor frame up the same way as a dozer.)
The actual effects of this effort of forcing the loaded blade sideways depend on whether you have an outside mounted blade or an inside mounted blade. With an inside mounted blade - i.e. a PAT blade - the loads are transferred direct to the tractor's main frame and thus do not stress the track frames and walking gear like an outside mounted blade. Turning a loaded outside mounted blade causes stress on the blade push arms, sway braces, push trunnions AND on all the track frame mounting/pivot points, diagonal braces, etc.. The sharper the turn, the more stress is imposed.
Having said all of the above, most crawler tractors these days are designed to have some 'heavy-handed malcontent' ignoring the agonised screams of the tractor and turning a loaded blade anyway.
I can't say with any degree of certainty about other makes but I suspect that Cat have for a VERY long time been aware of the punishment that steering clutches and brakes take on a dozer and have designed these parts accordingly. My own approach is to turn a loaded blade as little as I possibly can, even to double handling the load at times. This involves pushing a reasonable quantity of material to the turn point, then getting behind it to push it the rest of the way in the new direction.
If I do have to turn a loaded blade, I use small turn increments with brief disengagements of the clutch each time, a second or two at most.
A little handy hint, if I may. (Hee, hee, hee, yer too far away to stop me anyway.)If you have a hydraulic tilting blade, using the tilt to lead you into the turn can make life a lot easier for the poor tractor.
Hope this helps.
Thu, May 27, 2010 5:23 PM
D6c10K
Hi, D6c10K.
Hope this helps.
Thanks for the replies...kind of what I thought. The machine will take it, but shouldn't be done in a too jerky a manner. I do steer under load by tilting the blade when I can. To make that easier I just bought the joy stick blade control from a D6d to do away with the foot pedal tilt.
Thu, May 27, 2010 6:42 PM
83Jim
Send a private message to 83Jim
Reply to D6c10K:
I did something similar on my D4D. Nothing like figuring how to work an ol' foot tilt when you need to: steer the machine, raise the blade, hold the brake and change gears. Let's see that requires 5 appendages to do it right> So, guess we"ve just admitted our short comings! LOL
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Sat, May 29, 2010 1:05 AM
Online
Reply to D6c10K:
Hi, D6c10K.
Just as important as not jerking is not forcing the issue. If you do have to turn a loaded blade sharply, lift it a little to lighten the load. It can make a surprising difference to how easily a dozer will turn if you lift the blade by even as little as an inch or two.
I can relate to the situation with the foot tilt. I operated a D6C many, MANY years ago with a foot tilt and I thought it was one of the dumbest ideas that I had ever seen on a Cat dozer. In fact, I thought it was right up there with the hand-operated tilts that came out with the first Cat hydraulic tilt systems on the D8's and D9's where the tilt control lever was about 4 feet long and stuck up from the floor outboard of the powershift control. Steer (clutch and brake), tilt, lift blade all atta same time. Maybe also use the decelerater as well. A man needed a good few octopus genes in him back in those days.
BUT, they were still a LONG way better than not having a blade tilt. I cut quite a few double changes of elevation on S-bends with a hand-lever operated tilt system. The 769 pilots loved 'em.
Yer doo whut yer kin with wutchyer got.
Sat, May 29, 2010 4:53 AM
Hi, D6c10K.
Even something as simple as the way a hydraulic pump is powered makes a difference in operation of a new tractor driving style verses an old tractor. On our old oil patch tractors in PA. the pumps were all front mounted meaning as long as it was running, the blade was moving. Out here in WI, my D2 has a rear mounted pump meaning that at the end of a push there is a time lag before the blade goes up. Pushing dirt I always try to keep the clutch engagements smooth without too much jerk as I believe that it also effects every part in the system not just the clutches. When plowing or disking I try to go as long as possible without making a steering correction.
Sat, May 29, 2010 6:42 PM
rch101
Send a private message to rch101
Reply to drujinin:
"Kid; If it won't push the load with two tracks, it sure as h*** ain't gonna push it with one."
He said when the Dozer starts to drift, if you can't fix it with the tilt, stop and back up and pick up in the direction you want to go...
Sun, May 30, 2010 12:28 AM
