Serial info?
Serial info?
Showing 1 to 7 of 7 results
daron
I have a couple of inop 300A welders with D3400 engines on them and have a 5J D2 which needs an infusion of parts. I'm guessing that most of the engine parts are interchangeable.
Curiosity asks what the years of manufacture are for the two 3400 engines. One is 3S7765 and the other is 1J7365.
Thanks, Daron
Thu, Mar 25, 2010 12:51 PM
bruce oz
Thank you received: 20
hello daron,cannot help with parts info ,but serial number info below.
1J7365 , maybe 5j7365 is a 1945 model
3S7765 was built for 3 yrs from 1945-47
hope this bit of info helps,bruce oz
Thu, Mar 25, 2010 1:00 PM
Thank you received: 19
Reply to bruce oz:
Hi Daron,
3S7765 is a 1946 model.
Could not find a D3400 Industrial with a 1J prefix but there is a D3400 01T7001-up listed in the SNID (no year given)
Thu, Mar 25, 2010 10:07 PM
daron
Hi Daron,
What I listed as a 1J is actually a 1T (1T7563SP). Did the 1T precede or supersede the 3S series? Curious minds.
Thanks, Daron
Fri, Mar 26, 2010 11:16 AM
Reply to daron:
Thanks, Daron
As the 3S was carried up to 1948 I'd say the 1T preceded but I can't find and date info in what I have.
Fri, Mar 26, 2010 10:08 PM
When you do the parts infusion and figure out that cranks, cams, gears, rods, pistons, liners (all parts inside and outside the block) fit a J series engine. Maybe you can keep the good extra parts for resale? Someone is always looking for D2-J series engine parts.
Sat, Mar 27, 2010 12:17 AM
KCB
Send a private message to KCB
Reply to drujinin:
Daron:
Your engines were built as follows:
1T7563...1943
3S7765...1946
Here is the entire lineup for the D3400 Industrial Engines:
9J4001 thru 9J4909 built '39, '40, '41
3R6001 thru 3R6975 built '41, '42
1T7001 thru 1T9928 built '42, '43, '44, '45
3S7001 thru 3S8235 built '45, '46, '47
Basically these engines were all the same rating. Different serial number blocks were assigned over the 9 year production run. The engine family was replaced with the D311 Industrial engine in 1947.
Sat, Mar 27, 2010 7:25 AM
daron
Reply to KCB:
Daron:
1T7563...1943
3S7765...1946
Thanks all for the info. It looks like I have 'donors' as needed.
Thanks again, Daron
Thu, Apr 1, 2010 1:07 PM
