Trying to cross reference some spakre plugs
Showing 1 to 6 of 6 results
Dunefanatic
Send a private message to Dunefanatic
I am Trying to cross reference some spakre plugs marked AC 74 and AC76. Not sure if they are AC Delco. These are on a Wisconson motor. Trying to reference a contemporary replacement. Any help is appreciated.
Greg
Sat, Mar 13, 2010 1:19 PM
SJ
Send a private message to SJ
If you have a local NAPA Auomotive Parts Store they should be able to help you.
Sat, Mar 13, 2010 9:13 PM
OldNuc
Send a private message to OldNuc
Reply to SJ:
Check the NGK cross reference for the Wisconsin engine. Probably an AB-6 will work. I used to have a chart for those old industrial plugs but it went away and is hiding.
Sat, Mar 13, 2010 9:36 PM
Reply to OldNuc:
Current replacement is an Autolite 3076 or ACDelco C75 or Champion W14
This is a 7/8 in (22mm) x 5/8 in. reach plug.
Sun, Mar 14, 2010 1:16 AM
Dunefanatic
Thanks everyone for you assistance in crossing these plugs.
Pete, Your actual description sounds like them!
Again, much thanks!
Greg
Sun, Mar 14, 2010 11:49 AM
Reply to Dunefanatic:
Again, much thanks!
Greg
I thought "almost all" Wisconsin engines had Champion D-16's listed for the correct plug. Isn't a W-14 bigger?
Mon, Mar 15, 2010 8:27 PM
Reply to drujinin:
Yes, it is bigger, the D-16 is 18mm.
Mon, Mar 15, 2010 10:10 PM
