Engine stand pics
Engine stand pics
Pioneer1930
Send a private message to Pioneer1930
Anyone have a pic of their engine stand they made? I am getting ready to pull the engine on my D25J and my regular stand is in no way near heavy duty enough to hold it. I have plenty of steel and little money! I'd rather buy parts! Thanks!
Wed, Mar 3, 2010 5:52 AM
D6c10K
Send a private message to D6c10K
Here's one my brother built...has a salvaged worm gear to turn heavy eninges/transmissions. You can see in the pics that he makes special adapter plates for specific use. It usually mounts on the side of engine/trans rather than the end, but could be used either way.
Wed, Mar 3, 2010 8:38 AM
83Jim
Send a private message to 83Jim
Reply to D6c10K:
that is just sweet!!!
You only need two tools in life - WD-40 and Duct tape. If it doesn't move and should, use the WD-40 If it shouldn't move and does, use the duct tape.
Cat D4D 83J w 3304 PC engine, FOPS, s/t blade, D4F winch, air ride seat, "wobble" stick blade lever and D8H control panel
Cat 920 62K w 3304 PC engine, FOPS, 4 in 1 bucket
1995 Dodge Ram 2500 4x4 RCSB Cummins 5 speed
Wed, Mar 3, 2010 8:30 PM
CarlsCAT
Send a private message to CarlsCAT
Reply to 83Jim:
For what it's worth...I received a sales brochure from Harbor Freight today...One item got my attention...
ENGINE STANDS...
750 lb. capacity....$44.99
1000 lb. capacity....$49.99
2000 lb. capacity....$99.99
Thu, Mar 4, 2010 11:34 AM
Thank you received: 32
Reply to CarlsCAT:
ENGINE STANDS...
How much does the D2 engine weigh (roughly, including head, flywheel housing, sump)? It'd have to run close if not over 2000# wouldn't it? I'd love to only spend $120 on a stand that could safely support the engine...
Neil.
Thu, Mar 4, 2010 8:49 PM
Pioneer1930
Neil.
I'm pretty sure it's over #2000. I think i'm going to build one like D6c10K has posted. I'm not going to pull the motor until a little more snow goes around here. Thanks for the info.
Fri, Mar 5, 2010 9:32 PM
ronm
Reply to Pioneer1930:
I dropped by the HF store yesterday to kill some time waiting for an appointment & happened to notice the "2000 LB." engine stand....I would definitely not want to put anything bigger than about a 429-460 Ford or 454 GM on it to be safe...My big engine stand is loaned out right now, I'll try to get a pic of it one of these days if I'm out that way...it was built for 12V-71 Detroits, so most engines don't phase it a bit....I've had a 3306 on it, didn't even know it was there....
Fri, Mar 5, 2010 10:34 PM
CarlsCAT
I don't believe the diesel engine weighs over 2,000 lbs...
You will take the pony and radiator off...
I suggest you start a new thread asking for the weight of the D-2 engine...
Or, send OzDozer a PM, or IanOz a PM(private message)...or better yet...Willie...the new ACMOC leader...
Fri, Mar 5, 2010 10:39 PM
Pat in WI
Reply to CarlsCAT:
Pioneer1930
I helped a friend of mine build this test stand...it will adapt to almost any engine. OK...not a radial engine or large diesel or...etc
That is my TEN engine just before we started it for the first time. This was several years ago now.
Pat
Pat in WI
Sat, Mar 6, 2010 6:00 PM
