D4 7U Track Adjustment Question(s)
17 years 8 months ago #4092
by Al Ayotte
I have a 1956-or-1957 Cat D4 7U-38165. None of the manuals I have show a picture, a parts breakdown or discuss the track adjusting procedure for these tracks. I believe them to be an early hydraulic adjuster. Can anyone help me with this? I have attached pictures of the assemblies on my D4.
Al Ayotte
Al Ayotte
D4 7U; CAT DIESEL 35; CAT 22; CAT 30 (Wide Gauge)
17 years 8 months ago #4098
by bob
Al, they are aftermarket adjusters. Maybe "Timberline" If you need a seal for them try to get hold of a guy by the handle of "Halftrack" John Hopp. He got seal for a friends machine.
Later Bob
Thank you received: 815
17 years 8 months ago #4099
Hi Al,
Ok, I'll have a go:D
....I'd say those are an early version after market hydraulic adjuster alright, prior to the Cat version coming out on the D4 at sr. # 42,915. Usually there are two grease fittings, one to pressurize and one to release. I only see one source to tap on the ones you have so I guess you make connection and pump grease in until you get the proper track adjustment (1-1/2 in.) raise over the carrier roller.
I also have a request, seeing your good with the camera. I see you have a slightly different style of inside support bracket for your blade frame mounting. Is this on a five roller frame by chance? If so I would appreciate a picture of that inner support bracket if you would be so kind. Thanks
17 years 8 months ago #4121
by SJ
Where have you been "Bob" we haven,t seen you on in a long time so good to see your back and ok.I got your PM I guess was at Christmas time & glad to hear from you.We need a Cat service tech on like you to help guys on esp. a little newer machines. Ken.
17 years 8 months ago #4129
by bob
Had a problem getting registered Ken. Compuserve changed my Email address so the reply from board bounced back. Things went good when I found out about that and corrected it. Good tobe able to post again.
Later Bob
17 years 8 months ago #4150
by Al Ayotte
Bob: Thanks for the input. Can you give me any contact info for "Halftrack"? Also, was "Timberline" the manufacturer of the3 aftermarket adjuster(s)?
Thanks,
Al Ayotte
Al Ayotte
17 years 8 months ago #4151
by Al Ayotte
Thanks for your input, Old Magnet! My machine has the 4 roller configuration, but If you want those pix, I'll take them and send them off for you. Let me know.
Thanks again, Al Ayotte
Al Ayotte
17 years 8 months ago #4152
Hi Al,
Thanks for the response, yes I'd still like a picture of that inside bracket, somethings different there:)
You can usually raise "halftrack" on his IBDozing site:
www.ibdozing.com/
Thank you received: 44
17 years 8 months ago #4257
Thanks for the joint effort on the pictures:D
It's the view in picture #3 (your # 10004) that intrigues me. The brackets I have do not have that tapered (figure) shape and mine are much wider (4-bolt to the frame)
I was wondering if it was a Cat variation to accommodate the five roller frame as the five roller versions I have seen have a big (crude) notch cut in them to clear the spring when the whole mounting group is shoved forward on the frame.
See you have the direct start provision (cover plate) ready to go:)
Thanks.
Time to create page: 0.196 seconds
