2 Ton Tractor Web Site
Showing 1 to 10 of 39 results
§wishy
Send a private message to §wishy
[b] OK
RE: 2 Ton Tractor Web Site
Is there a Web site dedicated to the 2 Ton Tractor?
A web site of info n pics of these beasts?
Q😕 How many of U out there in Cat land own such a beast
Or is there a need for a web site for the 2 Ton Tractor??
Q😕 can all of these B classed as the same machine
HOLT 15-25, Holt T-35, Holt 2Ton, Caterpillar 2 Ton
any more to add to the list?
What B this Green Beast?
[img]http://img188.imageshack.us/img188/3761/malow.jpg[/img]
Us Cat 2 Ton owners need to stik together
LOL
Thanx in Advance
cya
§wishy[/b]
[CENTER]🙄 - : [B]ButEyeDoSt&2BCorrected : - 😛
Ifn U Get my Drift[/b]
😮 [/CENTER]
Tue, Jan 26, 2010 12:37 PM
Willie
That green beast would be a Holt exspearimental . It is the only one of its kind and I have drove it many times it belongs to Tom Madden in Paso Robles CA heres a pic of it and its owner on parade in Tulare
Tue, Jan 26, 2010 1:01 PM
§wishy
Reply to Willie:
[b]Willie
GuddayM8
RE: The Green Machine
What model ?
Would it be classed in the same stable as the 2 ton
Q😕 How many 2 Ton tractors duz Willie own?
Thanx for your input on the subject
Cya
§wishy
HasBeen[/b]
😮 [/CENTER]
Tue, Jan 26, 2010 1:07 PM
Willie
Reply to §wishy:
[b]Willie
GuddayM8
What model ?
Cya
§wishy
HasBeen[/b]
Swishy I have 7 2tons some Holt some Cat they are lots of them around here and and for the short time they were made they probably had more changes made then any other Machine. 3 diff makers of the engine first few had porthole on side ,carb changed a couple times, air cleaner system changed, had a few diff colors, steering levers changed size and shape, couple diff seat styles. Hard to steer and jerky takeoff. It had few uniuqe things, the first had oiltanks that dripped oil on the trackpins and bushing that was a disaister and many were made with the tank left on but no drip mech. and they had wet steering clutches and brakes
The green machine is more 5ton
Tue, Jan 26, 2010 1:20 PM
kejoycats
Send a private message to kejoycats
Reply to Willie:
Hi Willie
I have a 2 ton cat, the original paint seems to be green.
The tractor number is 75859. Could you please tell me if green was the original colour?
kejoycats
Wed, Jan 27, 2010 2:38 AM
Reply to kejoycats:
Hi Willie
kejoycats
my Holt T 35 (2 Ton) #70253 was also green under the yellow.
Wed, Jan 27, 2010 4:41 AM
Atlas
Send a private message to Atlas
Reply to edb:
Hi Swishy .Can anyone tell me why the 2 tons are so high geared in first gear they gallop like like a horse. Atlas
Wed, Jan 27, 2010 5:46 AM
Tom Madden_archive
Reply to Atlas:
CWish:
The picture you posted as Willie said is listed in one of the Dotted Lines as a "1917 Experimental". This tractor has been discussed with many of the "historians" concerning the accuracy of that designation. Some believe it was built in the 1919-20 time frame and others believe it predates the Holt Military 5 Ton. What seems to be clear is that it is the forefather to the Holt 5 Ton that was produced post WWII. When we were going through the tractor we referred to it as a 3 1/2 ton because that is about what it weighs.
The serial number is 11679 which is second in the production of about 7 different models that contributed to the design of the 5 Ton. This tractor was tested, broken and put away long ago and was found by Fred Heidrick Sr. I bought it from the family after Fred's death.
The reason it was not used much is that the draw bar was broken completely off as was the belt pulley. What good is a tractor that cannot pull an implement or power stationary machines such as threshers or pumps. Don Hunter fabricated a complete new draw bar and repaired the belt pulley so all is operational.
When the heads were removed it revealed machining marks in the bores--almost no wear! The sprockets and remainder of the u/c is essentially new; we did have to fabricate one track pad and section of rail as one was missing.
Sooooooooo, the rather long answer to your short answer is that the green tractor is not a 2 Ton.
Wed, Jan 27, 2010 6:21 AM
JasonPayneCrawlers
Reply to Tom Madden_archive:
CWish:
Tom
Great looking machine, I would guess that I would have to were a bib if I were to look at your collection😊
Wed, Jan 27, 2010 6:41 AM
Tom Madden_archive
Reply to JasonPayneCrawlers:
Tom
Jason:
Come on out to the Best of the West and you can drool all you want!! I am very fortunate that I have been entrusted with the care of some outstanding iron.
Tom
Wed, Jan 27, 2010 6:51 AM
JasonPayneCrawlers
Jason:
Tom
Tom
The show is near what airport, thanks😊
Wed, Jan 27, 2010 12:26 PM
Chapter 2 The Link Club's AGM
