212 Grader Brake Drum (Max Diameter)
660 Scraper
Send a private message to 660 Scraper
We have a Customer who is repairing a 212 Grader (95C00015) and has asked what is the max diameter the wheel brake drums can be machined out to. I believe the part no. for the drum is 7B1399.
If any one of the members would happen to know this info, your help would be greatfully appreciated.
Tue, Jan 5, 2010 10:29 AM
I couldn't find any info on resurfacing drums other than they are 16 inch diameter and a 3 inch wide drum. Maybe edb might have something.
Tue, Jan 5, 2010 12:34 PM
OldNuc
Send a private message to OldNuc
The 212 probably predates regulatory involvement in brake drums. I have never seen anything relating to max diameter in any of the books that I have. Some older drums have a mark on the edge for the max diameter.
Tue, Jan 5, 2010 9:40 PM
Reply to OldNuc:
from The Dealer this is the only chart I have, but I feel the 3mm/0.125" Max. above Standard cited here would be acceptable for your 212.
The sizes given on the chart are the specification standard size for that P/No.
So The max size is that given dimension +0.125"/3mm
I do not have a P/No for your drums or a Standard size, maybe some one else can help further.
Hope this helps.
Wed, Jan 6, 2010 1:19 PM
660 Scraper
Reply to edb:
Hope this helps.
Thanks for all your assistance from WA Tech team
Thu, Jan 7, 2010 10:42 AM
| Hartley - South Australia
