Login | Register
Pony Motor Piston Replacement
Showing 1 to 10 of 12 results
Vinny
Send a private message to Vinny
Cat sells replacement piston's that 60 thousands over. Since no one seems to have the equipment to grind or turn these down to fit the cylinders anymore I was wondering if someone has some idea's on how to get it done right? My machineist informed me that cylinders are not exactly round and that if the piston was turned down it would be round. He was afraid that there was a good chance of the piston catching. Has anyone had to go through this before?
Tue, Mar 6, 2007 9:12 PM
SJ
Send a private message to SJ
Sounds to me like your best bet is bore the cylinders to the .060" over, that,s if you can get the rings for it.I,m not sure whether the pistons are cast for oversize in the structure or not so don,t know if the walls of the piston would be too thin if they were cut back to std. Maybe if you have more questions then go to an automotive machine shop & talk to the foreman for what,s best.At the Cat shop I have rebuilt dozens of starting engines & if the cyl. walls were worn then they were bored to clean them up & install the pistons to the fit & rings. Also many of them we put dry sleeves in the block & went back to std. size if the bores were excessively worn or scored.
Tue, Mar 6, 2007 9:59 PM
Vinny
Reply to SJ:
I'm wondering if I may be going about this wrong. It started out that the Machinist informed me that the top ring lands were in bad shape and that he thought I should replace the pistons. So..., how about this? Is there any place that I could buy replacement pistons that would fit my cylinders?
Vinny
Tue, Mar 6, 2007 10:24 PM
SJ
I,m only saying what can be done but if I were you I,d take the block to an automotive engine rebuilding shop & have them check out the bores & see what is the way to go either bore oversize or sleeve the block.I don,t know if NAPA has pistons available or check with another Cat dealer for different size pistons if you overbore or back to std.with sleeves being installed.Guys on here post many places that sell Cat parts so when you find out what you need then check with these outfits to see if they can help. Even the Auto. machine shop might be able to help you with pistons. What is this starting engine out of?
Tue, Mar 6, 2007 11:24 PM
Vinny
Reply to SJ:
Thanks SJ,
I talked to the machinist again and he's thinking that they may be able to do something with the Cat replacement pistons but he has to see them first. The pistons came out of my D-2's Pony motor. I don't think my machinist has done any starter motor rebuilds before but I know he's very good at his trade, so maybe once he has a chance to look them over he will be able to get er done.
Wed, Mar 7, 2007 12:30 AM
SJ
Cat had thicker rings for the diesel engines to install if the lands got worn as I have cut lots of the diesel pistons & installed the wider rings.I don,t know if the wider ones are available for the starting engines or not but you could ask when you talk to your machine shop what can be done.When I was working yet there was no problem you just chucked the old ones & put new pistons in but today things aren,t so available so you have to go the route to get things done as parts availability is the thing.
Wed, Mar 7, 2007 1:02 AM
Reply to SJ:
Hi Vinny and team,
Serv. Mag. Jan. 18 1949 page 4 tells us that that a chart is included with dimensions for reboring starting engines and required piston dimensions to suit.
It goes on to say that:- "SOME pistons used as original equipment had tapered skirts, but the most practical way to finish pistons in the average Dealer's shop is to finish the skirt straight. Taper turning or grinding requires additional expensive shop equipment, and our experience has been that starting engine pistons with "straight" skirts will give satisfactory results".
I believe that the same piston body part is used for all pistons for a given engine and they are machined for the O/S required or even back to standard, laterly I believe only semi-finished pistons are available, I think there is a S/M covering this also, I do stand to be corrected on these last points.
If you let me know which starting engine you are working on I can pass on the dimensions from the chart, maybe if Ozdozer has it he may be able to post it? PLEASE.
SJ my arms still ache from turning those Manulathes to widen the ring grouves for D4/6/7&8 pistons as an Apprentice. See S/M May 31 1950!.
Regards
Wed, Mar 7, 2007 9:21 AM
OzDozer
Reply to edb:
Hi Vinny and team,
Regards
Eddie - If I'd known you had such fond memories of those old Manulathes .. I'd have pointed you in the direction of this one, that was available just last week .. 😄
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ih=009&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=190083195411
Here's the starting engine piston-cylinder reboring specs from Jan 18 1949, that you speak of ..
http://img227.imageshack.us/img227/2229/startingenginepistoncylcm8.jpg
I've left if full size, and in landscape format, so that the figures aren't squashed-up, and so it prints out better ..
Wed, Mar 7, 2007 4:02 PM
OU@AL
Send a private message to OU@AL
Reply to OzDozer:
[quote="OzDozer"]Eddie - If I'd known you had such fond memories of those old Manulathes .. I'd have pointed you in the direction of this one, that was available just last week .. 😄
I've left if full size, and in landscape format, so that the figures aren't squashed-up, and so it prints out better ..[/quote]
OzDozer, does the chart apply to the pony engine on the D4-7 U also?
Wed, Mar 7, 2007 10:36 PM
Reply to OU@AL:
Hi OU@AL,
the Horizontal 2 3/4" bore line is your S/Eng.
This line covers starting engines for:- D3400, D4400, D311, & D315.
Ozdozer
thanks for posting the above, I did eventually find my copy but I dont yet have the puter savvy to put the scaned in data into a post YET!.
Some years back I scavanged several profesionally bound books of S/M's, P/B's, P/L's & SNL's from the bins at the dealer. Some of these dont lend themselves to opening out to scan properly. Just now trying to get going again after dealing with DVA for 3 years.
I get the LOOK when I bring even these books inside, I thought they looked OK being bound in leatheret and gold embossed down the spine.
Regards
Thu, Mar 8, 2007 5:42 AM
OzDozer
Reply to edb:
Hi OU@AL,
Ozdozer
Regards
Eddie - Good to hear you managed to save the Service Info literature from the bins. We'd probably weep if we knew what was thrown out. I managed to score some stuff from a country IH dealer here, after he sold his dealership.
He said when Westrac were under poor management in the late 1980's, and they closed a number of country branches, he found the local Cat blokes up at the rubbish dump, dumping boxes and boxes of literature galore.
When he asked what they were doing, they said they just had instructions to dump everything that was in the branch, because it was being closed down, and they wanted the property clean, so they could sell it .. 🙄
He managed to officially redirect a lot of stuff to himself, by telling Westrac he had IH's with Cat engines in them (which was true) .. but the basis of his decision, was that he was just appalled at the waste of useful info, and had to try and arrest it. He said a substantial amount had already been buried, before he found out (accidentally) what was happening.
Yes, the professional bindings of a serious number of copies make it hard to scan them. I often take a (digital) pic of a page, if it's too hard to scan .. then load the pic into the computer.
Glad to hear you got onside with DVA. I know that feeling. They wanted more info from me - so I gave them a 48 page submission .. with a heap of pics such as you saw on the ACME post.
Coupled with a very good RAAF woman advocate from the RSL, who walked me through the 'Veterans Entitlements Act -1986' (a minefield if ever there was one), we got DVA onside .. but only after they took 18 months to come to a decision to classify me as TPI.
Like so many Govt Depts, I think they either want you to give up or die. Too many good blokes have done both, whereas they deserved better from DVA. Some of the stories the advocate told me, about blokes who were more than entitled to TPI, but who went about their application the wrong way, and were rejected, would make you spew.
Thu, Mar 8, 2007 6:56 AM
KORUMBURRA WORKING HORSE & TRACTOR & 100 YEARS OF CAT RALLY
| 5875 STH GIPPSLAND HWY, NYORA
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
