Cat 22 shift pattern
Peter C
Send a private message to Peter C
What is the shift pattern for a Cat 22 2F?
Tue, Dec 8, 2009 1:56 AM
shovel man
Shift pattern as follows.
Reverse. forward left
1st forward right
2nd back left
3rd back right
I'm fairly certain all 3 speed tractors like Ten, Fifteen Twenty Two etc use this shift pattern but somebody out there will correct me if I'm wrong!
hope this helps.
Shovel man.
Tue, Dec 8, 2009 3:29 AM
Peter C
Reply to shovel man:
1st forward right
2nd back left
3rd back right
hope this helps.
Shovel man.
Thanks for the response, Shovel man
Tue, Dec 8, 2009 11:04 AM
B4D2
Reply to Peter C:
Don't forget about the "lockout" portion of the pattern. The shift pattern includes a slight sideways loading that prevents you from coming out of gear while under power. As an automotive pattern is typically an "H," the older Cats use the same, but the shifter lever is loaded to slide to the center of the shift pattern to lock into gear. If your machine is parked in gear, and you can't just pull the shifter back to neutral, push slightly away from center and downwards (or upwards depending on where in the shift pattern you are) to reach neutral.
Tue, Dec 8, 2009 9:56 PM
OzDozer
Reply to B4D2:
Dana & Roddy Reid have the Caterpillar 22 website set up with the full operators instructions scanned .. along with galleries, brochures, links, contact with other owners, and a Cat 22 bulletin board ..
Caterpillar 22 website .. http://www.angelfire.com/home/cat22/index.html
Wed, Dec 9, 2009 10:25 AM
