Wow! Brand New High clearance Sprocket!
Showing 1 to 10 of 11 results
Highwide20
Send a private message to Highwide20
We were visting famliy this weekend in Wisconsin and thought I'd swing by and look at Bob Stewerts Holt 75. Sitting on the front wheel of the 75 was the 1st prodotype High clearance sprocket. Could not belive it. I know he was talking about it a while back but had no idea that he was going to go through with it. Sure looks good! Also as you can see the new dirt guard that is a formed piece not 2 parts welded. It's going back to the machine shop to have the spline's cut in the hub Monday. Mike
Mon, Nov 30, 2009 10:53 AM
JasonPayneCrawlers
Mike
When Bob had it casted do you have to have one that is mint to cast from or can they fix it in the mold before they pour the new one?
Mon, Nov 30, 2009 11:26 AM
Highwide20
Reply to JasonPayneCrawlers:
Mike
Bob had a pattern made. Because of the shrinkage of steel when you pour it. A pattern has to be made 1/4 inch bigger per foot to allow for skrinkage. Mike
Mon, Nov 30, 2009 12:17 PM
cr
Send a private message to cr
Thank you received: 13
Reply to Highwide20:
When a pattern maker makes a pattern he uses what is called a "shrink rule" or some places called a "pattern makers ruler" that still reads like a normal rule but has been scaled for this shrinkage for the particular material being cast. As stated steel is 1/4" per foot cast iron is 1/8" per foot.
http://www.freemansupply.com/StarrettSteelShrin.htm
Mon, Nov 30, 2009 2:07 PM
squeakytracks
Send a private message to squeakytracks
Reply to cr:
very pleased to see such attention to detail and care, looks awesome. are you goin to get into making and selling these or is this just for a crawler you have? ps. cool struck.MikeN
Mon, Nov 30, 2009 8:07 PM
Caterpillarman
Send a private message to Caterpillarman
Hey Cat Iron, Just out of curiosity, is that the Holt 75 that Rod Herrick used to have? Caterpillarman
Tue, Dec 1, 2009 11:53 AM
side-seat
Thank you received: 8
That's some fine workmanship Bob. Are they going to be cast steel? Is the machine shop going to machine the sprocket teeth and heat treat the teeth also?
Wed, Dec 2, 2009 5:22 AM
hiwide15
Send a private message to hiwide15
Reply to side-seat:
If you cast the best 2speed sprocket I want a set .
Ron Meeder best no. 1624
Wed, Dec 2, 2009 5:59 AM
Dunefanatic
Send a private message to Dunefanatic
Reply to hiwide15:
Hey Bob, Sent you a PM note regarding the sprockets. Greg
Thu, Dec 3, 2009 11:43 AM
wimmera farmer
Reply to Dunefanatic:
Certainly looks like a good job never underestimate the skill of a pattern maker it is almost a lost art today compared to the foundry work done in years past.
Hiwide 15 you have my attention can you please post more detail on the two speed Best sproket reffered to in your post. This is just for those like me who have never seen a Best tractor and some of us likely never will.
cheers wimmera farmer
Thu, Dec 3, 2009 6:27 PM
side-seat
That's nice to know that the sprockets will be better than the originals Bob.
Thu, Dec 3, 2009 8:53 PM
