Cat Ten Lights Setup
Showing 1 to 10 of 27 results
JasonPayneCrawlers
Does anyone know how the light set was setup on a Ten. I took a pulley off a Ten and it has a slot for two belts,looks like some one cut one pulley and added it to the other they did a nice job but you can tell it was not factory.
The generator mounted to the block were the four bolt holes on the upper top side of the motor on the same side of carburetor I think.
Does anyone remake the light brackets and is there any small generator's that could be used
Does anyone have a made up light system on a Ten😊
Thu, Nov 26, 2009 10:24 AM
Willie
Jason in my part book it looks like they only used a single pulley but longer belt for gen. It also shows they used 2 diff makes of lights simular in style the guide with little knob behind it& Do-Ray Double contact and the early big flat lens type like 20 and early 30s used but i have seen them in pics with
later style 7" guide lights that are most common and some with the Can type like AC used on the early crawlers so you need to know what type you plan on using to get right bracket
Thu, Nov 26, 2009 11:12 AM
JasonPayneCrawlers
Reply to Willie:
Thanks Willie I will look for some lights and take it from there😊
Thu, Nov 26, 2009 11:36 AM
Reply to JasonPayneCrawlers:
I believe I might have a photo of an aftermarket setup, as the little TEN in the photo has an electric starter also. Your right in that the gen is on the carb side.
Thu, Nov 26, 2009 8:19 PM
JasonPayneCrawlers
Reply to drujinin:
What size lights and make are these on this Ten😊 Did someone fix up Kevin Kalsem Cat Ten not sure who he sold it to😕
Fri, Nov 27, 2009 2:35 AM
Jason 10/D4
Jason not sure but i think that is Pat from N Carolina ten and I think he said those lights were off a buick form the 20's. Jason
Fri, Nov 27, 2009 3:49 AM
brewzer
Here is a picture of the generator and lights you need. If you find either one go out and buy a lottery ticket. Chances are about the same.
Fri, Nov 27, 2009 2:44 PM
JasonPayneCrawlers
Reply to brewzer:
Brewzer
Thanks for the pics. I have been told they are very hard to find. I guess not many Tens had the set up for lights.
Sat, Nov 28, 2009 12:26 AM
Jon
Send a private message to Jon
Brewzer
a picture of my ten with lights. these are Guide lights and have the same lenses as the large (9 1/2") caterpillar lights and are the only ones i have ever seen.
Sat, Nov 28, 2009 2:42 AM
brewzer
Reply to Jon:
Jon
You have the air cleaner top that I usually see on Bishop fendered 10's. Do you know anything about the history of these different tops and carb elbows? - Wally
Sat, Nov 28, 2009 6:45 AM
JasonPayneCrawlers
Reply to brewzer:
Jon
Jon
Thanks for the pic you are sure lucky to have that setup on your Ten😊 Great looking machine😉 Do you have a close up of the light bracket front and back?
Sat, Nov 28, 2009 10:17 AM
| Hartley - South Australia
