decode serial number
Showing 1 to 10 of 14 results
rditz
Send a private message to rditz
general question, is there a place or someone that could decode a Cat serial number??
I have a 955 and have found the engine plate.. i can only make out 12A1379.. i believe there should be another two characters, but they are worn and i cannot make out anything of them..
any information on this number is appreciated...
thanks
rod
Thu, Nov 12, 2009 7:44 PM
SJ
Send a private message to SJ
Normally there are two places for serial numbers and that,s on the left rear side of the engine block below the head and the other on on the back housing above the drawbar.If the plates are missing the numbers are stamped in the casting between where the plate was riveted on.
Thu, Nov 12, 2009 11:46 PM
rditz
Reply to SJ:
thanks, i will look tonight
Fri, Nov 13, 2009 12:47 AM
bruce oz
Thank you received: 20
Reply to rditz:
hello rditz,i am not sure if cat used sp after loader serial number ?.
the serial number for 955c 12A1379 is 1956 built .
bruce oz
Fri, Nov 13, 2009 1:59 AM
rditz
Reply to bruce oz:
bruce oz
thanks... if i find additional digits from the casting, will that affect the year at all??
rod
Fri, Nov 13, 2009 2:18 AM
bruce oz
Reply to rditz:
rod
hello rditz,the ex info on the tag want change yr built ,12a8418 was the last one made .if you are looking for track parts they change from d4 size track to d6 size tracks after serial number 12a 5792 ,cannot say if there were other changes ,someone else may have that info. if you buy manuals make sure they suit your serial number range,engine fitted to your 955 was d315 ,bruce oz
Fri, Nov 13, 2009 2:41 AM
rditz
Reply to bruce oz:
Bruce Oz,
thanks for the info... I definitely want to get service manual... and the concren was making sure i got the right one.
rod
Fri, Nov 13, 2009 3:33 AM
rditz
Reply to rditz:
Bruce Oz,
rod
I cleaned off the back section of the loader and discovered a different serial number than the engine.
engine s/n is 12A1379
chassia s/n is 7U40773
can someone decode the chassis s/n??
i guess it is possible that the engine could have been changed.
thanks
rod
Tue, Nov 24, 2009 8:47 PM
catsilver
Reply to rditz:
thanks
rod
All the different serial numbers mean is that the original back-end case which carried the same serial number as the engine has been replaced with a used one from a D4, 7U series machine, probably due to a back-end case failure .
Tue, Nov 24, 2009 9:33 PM
SJ
Reply to catsilver:
Rditz, Did you post the engine and chassis just opposite from what you should have or maybe as was mentioned a rear housing was replaced some time and the SN is on it from the 7U tractor.
Tue, Nov 24, 2009 11:54 PM
rditz
Reply to SJ:
originally, i could only find the serial number on the engine. I believe that there are two digits that I cannot make out...
but then i found the one on the back...
what would the approximate year of manufacture be for a 7U??
which is more likely, rear housing change or engine change??
thanks
rod
Wed, Nov 25, 2009 12:16 AM
