Belt Driven Generator Replacement
Showing 1 to 10 of 12 results
mtgstuber
Send a private message to mtgstuber
Well now that my D6 is running . . . We're into winter and out of daylight. With the switch back to standard time and our northern lattitude, the sun is setting at 4:30. Ugh. The generator on my D6-9U (S/N 1417) appears to be long since dead. It's belt driven, and seems to spin okay, but that's about it.
It would be really nice to have some lights on this beast. Any thoughts about the sanest way to swap out the generator for an alternator? (I read the thread on gear driven units, but that doesn't seem to apply -- at least not directly)
Michael Garrison Stuber
D6U, #12 Grader, 2 Alpacas, 4 goats, 3 barn cats, a black Russian Terrier, and lots of trees.
Sun, Nov 8, 2009 7:31 PM
To replace a large framed generator like was common on the older equipment, you can usually fit an alternator off a large truck to the same wide spaced mount. The larger alternators will probably take a larger variety of pulleys than the standard Delco, Ford, Chrysler, or Motorolla automotive designs. A heavy truck parts supplier or junk yard would be a good source if you don't already have one sitting out back.
If you want to go with a compact alternator, the Delco 10SI is about the standard for the type and are commonly available and usually pretty cheap. You will likely have to make a bracket or make modifications to the existing one to use one of these and find a pulley that fits the belt.
A picture of the current generator would be interesting if you can post one. I guess it was standard before the gear drive generators came in? Or maybe a later addition?
Tue, Nov 10, 2009 3:33 AM
mtgstuber
Thanks. I've got an early unit, so I suspect it's original -- pre-gear driven. I don't have any old trucks kicking around, so I'll have to do some external scrounging, or put together a bracket. I'll post a picture once I get back home -- I'm on the road this week.
Tue, Nov 10, 2009 9:21 AM
mtgstuber
Reply to mtgstuber:
Apparently I was confused. My is gear driven. Silly me.
Sun, Nov 29, 2009 5:00 AM
Thank you received: 19
Reply to mtgstuber:
Was kind of wondering about that.....never seen a factory belt driven generator on the D318 until you get to the "G" series industrial engine. Hesitated to say so...ya never know😉
Sun, Nov 29, 2009 7:03 AM
jw45
Send a private message to jw45
just completed mine some pictures i machined a replacement shaft for the gen armature then fabed my adjust bracket to bolt on where brushes and other were mounted this closed off holes keep dirt dauber out there is room in back housing for 2 bearings the shaft long enough to protrude out end i put an larger pulley on shaft to overdrive the alt to put out 45 amp at idle this way if i ever want to i can change it back to gen very easily
Mon, Nov 30, 2009 8:09 AM
whiteiron
Send a private message to whiteiron
Reply to jw45:
Just find a good stock generator and convert it to 12 volts with external regulator, lights will be a little dim at an idle but it'll work.😊
Mon, Nov 30, 2009 8:53 AM
OzDozer
Reply to whiteiron:
jw45 - That's nice workmanship. Does the alternator and mountings stand up to the vibrations and shaking of the tractor, O.K.?
Mon, Nov 30, 2009 9:08 AM
Reply to OzDozer:
Versions of that have been around for a long time....seem to work ok.
Mon, Nov 30, 2009 9:39 AM
jw45
yes it seems to hold up very well now as far as the generator is concerned it is a stock gm generator used on these machines the gens off the 50 model d cars and trucks will bolt up to the front housing but this alt conversion is a whole lot better
Mon, Nov 30, 2009 10:15 AM
mtgstuber
Reply to jw45:
OM, it that a hydraulic pump in that one picture? What is it driving?
Mon, Nov 30, 2009 10:23 AM
