7U pto photo pse
7U pto photo pse
Showing 1 to 10 of 13 results
kiwicats
Send a private message to kiwicats
hi folks,
does anyone have a clear photo of the 'engaging lever' on a D4 7U single-speed pto?
i'm having trouble finding one, so may need to fabricate. the parts book doesn't really show the bend angles well.
part # 3B 1169 (lever) and #3B1168 (2x brackets).
thanks.
rgds from NZ,
peter.
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
D4 (4g,7j,2t,5t,6u,7u)
Diesel 35
D8 (8r)
Mon, Oct 12, 2009 1:31 PM
bruce oz
Thank you received: 20
Mon, Oct 12, 2009 2:33 PM
Thank you received: 19
Reply to bruce oz:
hello kiwicats,the angles look ok ,you will have to work out the lengths ,bruce oz
.[img]http://img114.imageshack.us/img114/7125/d47usinglespeedpto.th.jpg[/img]
[img]http://img114.imageshack.us/img114/6255/d47usinglespeedpto1.th.jpg[/img]
At one time I was running this fabricated version....had to redesign later when I added 3-pt and side tank.
I didn't think much of those angle iron support brackets so fabricated the supports you see with blind tapped holes that use the seat tank mounting bolts along with nylon bushings for the control rod.
Mon, Oct 12, 2009 10:33 PM
kiwicats
thanks guys.
isn't this a great resource...
rgds,
pt
2 Ton
10
15
22 (2f,1j)
R4
D2 (3j,5j,4u,5u)
Diesel 35
D8 (8r)
Tue, Oct 13, 2009 3:04 AM
Mike The Man
Send a private message to Mike The Man
Old Magnet would you have any of the pictures showing the 3 pt you installed
that we could view?
Mike
Sat, Oct 17, 2009 9:33 PM
Reply to Mike The Man:
that we could view?
Mike
Mike,
Did you check the archives?? there were progress pictures posted when fabrication was in progress (several years ago)
If you can't find them I can re post some.
Check the current post on "D4 Service".
Sat, Oct 17, 2009 10:36 PM
SpragueM
Mike,
All the links to the old come up 404. Hope someone else has more luck.
http://acmoc.phpwebhosting.com/viewtopic.php?t=2777&highlight=hitch
Matt
Sun, Oct 18, 2009 12:46 AM
Reply to SpragueM:
Matt
I recall a statement from Joe B saying everything was saved๐Ÿ™„ ๐Ÿ™„
Didn't say where......looks like some questions need answering.
Sun, Oct 18, 2009 2:08 AM
SpragueM
This is how all of the shortcuts I've saved from the old board come up. Combined with all of the photo's that people have removed due to space limitations, a lot of history is non-existent.
Hope it's somewhere. Wasn't this part of what the ACMOC board payed to have done? Who dropped the ball?
Matt
Sun, Oct 18, 2009 2:18 AM
Reply to SpragueM:
Matt
It's more of a case of no one picked up the ball๐Ÿ™„ ๐Ÿ™„
I quit carping about it a long time ago as it was/is not a politically correct topic.
Sun, Oct 18, 2009 2:22 AM
SpragueM
I know you have OM. A lot of what is missing has come from you, glad you had the insite to archive what you have. Don't mean to hijack this thread but
it comes up over and over again. Guess it isn't important until it happens to you.
If there is some way I can help get it back let me know. Will start a new thread.
Matt
Sun, Oct 18, 2009 4:12 AM
