4C serial number engine
17 years 8 months ago #3462
by Jdnut
I went to look at a Cat powerunit that was out of what I would guess a home made locomotive. It had a non cat radiator and a non cat transmission the rest was gone. Initially I was told it was a D7 engine, but on arrival it is a 3 Cylinder engine that lookes like maybe it went to a Diesel 35 or something like that.. I am not very familiar with the three cylinder cat's. When I was at Dick Lloyds a few years ago he has a bunch of them.. one in a grader, some in cats..
Anyway, the serial number of the engine start with 4C....
Chris
Chris - Jdnut
Located in Stanwood, Washington
Collector Of:
Bucyrus Erie - 15B 20B 22B
Caterpillar - 8U D6, 3T & 4T D7
Kenworth - W900 & W925
John Deere - A's B's R's
Drott - 50 DC
Thank you received: 815
17 years 8 months ago #3466
Hi Jdnut,
Quite a few power plants listed with 4C prefix but based on it being a 3-cyl it is probably a D6600 (5-3/4 x
or a D6100 (5-1/4 x
Thank you received: 344
17 years 8 months ago #3476
by edb
Hi Jdnut,
OM is correct as usual.
My 1957 vintage Technical Bulletin on Engine Model Id.tells us that most 4C S/No prefix engines are Gasoline Powered Industrial Units. Your 4C 3cyl. Diesel unit is listed as a D6100 Industrial, with S/Nos starting at 4C9001 built 1933/35, 47HP Intermittent rating, 3cyl., 5.25"+8" bore & stroke, 850 RPM full load rating. Hope this helps,
Regards EddieB.
17 years 8 months ago #3493
by Jdnut
Thank you both for the replies. I would assume that it is the older 6100 instead of the 6600. It has the older style injector housing. Although I don't realy know enough about it to be sure. That is just my guess.
Would the 6600 have been an early D6 or RD6 motor?
Chris
Chris - Jdnut
Collector Of:
Drott - 50 DC
17 years 8 months ago #3494
Hi Jdnut,
Yes, on the D6600.
The D6100 was used in the "35", & "40" model tractors.
I'm inclined to think you are looking at the D6100 power unit which would start with serial number 4C09001.
Quite frankly I don't know how you would tell them apart externally:confused:
Thank you received: 115
Time to create page: 0.155 seconds
