Kroil Oil
Kroil Oil
Showing 1 to 10 of 15 results
oldparker
Send a private message to oldparker
For those of you who want Kroil that is talked about so much, go to Google and type in Kroil Oil where to buy. A pop up menu will display where to call to get a deal direct from Kano Labs that make the stuff. You can get two cans for $12.00 with free shipping. Mention that this is the Google deal. I just got my second two cans, so I guess that you can use this deal more than once. It is really great stuff. John
Sun, Aug 23, 2009 9:41 PM
Arthropod
Send a private message to Arthropod
Eastwood car restoration supplier (eastwood.com) sells it by the gallon or spray can. $80 a gallon.
Mon, Aug 24, 2009 7:27 PM
Reply to Arthropod:
kano laboratories
1000 e. thompson ln.
nashville, tn 37211
615-833-4101
Mon, Aug 24, 2009 8:18 PM
OldNuc
Send a private message to OldNuc
Reply to dpendzic:
kano laboratories
nashville, tn 37211
615-833-4101
The company site
http://www.kanolabs.com/
The Kroil google offer
http://www.kanolabs.com/google
Over on the machinery site they conducted a test and Kroil came out on top of the commercial products but a home brew mixture of 50/50 cheap ATF and acetone was slightly better as a penetrating oil.
Tue, Aug 25, 2009 12:53 AM
Arthropod
Reply to OldNuc:
The company site
Very interesting...
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load .. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10
The ATF-Acetone mix was a 50/50 mix (1 to 1 ratio)."
Tue, Aug 25, 2009 1:30 AM
bernie
Reply to Arthropod:
Very interesting...
the other surprise for me is that liquid wrench does a better job than pb blaster...
Tue, Aug 25, 2009 2:05 AM
Arthropod
Reply to bernie:
I don't know. I'm not that surprised about the PB. I bought a can of PB blaster some years back and other than foaming alot, it didn't seem to do much else for me to loosen rusted stuff. Liquid wrench was always what I went for until discovering Kroil a few years ago. This ATF/Acetone info is something I want to try. I just bought a set of new D2 rails that are rusted stuck in a coil. I sprayed all the pin/bushings with Kroil over the weekend and several of the links are moving now, which is really good news. I want to try this ATF mix to see if it works better.
Tue, Aug 25, 2009 3:28 AM
hicrop10
I have been using kroil for quite sometime and have had very good results.The only drawback is the price,but if it works then it well worth it.I will give the atf/acetone mixture a try.Where would you go about buying acetone?
Tue, Aug 25, 2009 5:14 AM
SpragueM
Reply to hicrop10:
You can usually find acetone in the paint section of a hardware store, gallons and quarts.
Matt
Tue, Aug 25, 2009 5:19 AM
Billy D7 4T
Send a private message to Billy D7 4T
Would have been interesting to see how this one does, it's an industrial strength, seems to work well in many instances, but like all, no miracles for the most part, it was retailing here for $9/ spray can, only 3 places I know carries it.
http://www.gasoila.com/products/items/freeallnew.html
Tue, Aug 25, 2009 8:51 PM
landreo
Send a private message to landreo
Those results are spreading far and wide but mean little. I have the original article. He put 1/4 inch pins in 1/4 inch holes and let them rust for 12 hours. The pins were originally "finger tight" which does not by it self make sense. A 1/4 inch dowel would not be finger tight in a 1/4 inch hole. The 12 hours of rusting was able to increase the finger tight dowels to over 500 lbs of resistance. Hard to believe for only 12 hours of rusting. The home made mix was actually power steering fluid not atf. The kroil may be good but I would not base any decisions on this article. No statistics were actually given and it appears he only used 3 dowels per test. Likely not a valid study.
Tue, Aug 25, 2009 9:35 PM
