Need info for D7 17A series
Showing 1 to 10 of 19 results
chriscokid
I found a D7 SN: 17A9921,
My spec. sheets do not include the D7 series, can anyone tell me year, HP, how many made, Wt. of tractor And pros and cons about this series.
Thanks,
Erik
Sun, Jul 26, 2009 8:07 AM
bruce oz
Thank you received: 16
hello chriscokid your d7 17A9921 is a 1957 built ,there were 19642 built as d7c and d7d ,1955 to 1964 ,bruce oz
80 hp .
Nebraska test 1940 -http://digitalcommons.unl.edu/tractormuseumlit/946/
spec sheet-
[img]http://img24.imageshack.us/img24/7186/page30y.th.jpg[/img]
sales brochure-http://s315.photobucket.com/albums/ll477/bacoly/d7/
Sun, Jul 26, 2009 9:42 AM
Reply to bruce oz:
80 hp .
spec sheet-
That appears to be the specs for the 3T series....The 17a used the D339 engine with early serial numbers ( prior to 17A1187😎 at 123 hp and bare tractor weight was 26,555 lbs. Direct drive, oil clutch, no turbo....a very good unit.
Sun, Jul 26, 2009 10:12 AM
bruce oz
hello Old Magnet ,here is the spec sheet i have for the d7 3t ,they both have the same Narbraska test number ,let me know which is rigth and i will change my info,is he sales brochure rigth ? ,thank you ,bruce oz
spec sheet d7 3t ?
[img]http://img44.imageshack.us/img44/4528/d73tspecifications.th.jpg[/img]
Sun, Jul 26, 2009 10:53 AM
Billy-
Send a private message to Billy-
Reply to bruce oz:
spec sheet d7 3t ?
The early D7 17A's are a very good tractor. There quite simialar to the old 3T series but have a totally redesgned enigne plus a few other small things and pull alot more as well. You can lug there engines down till you can just about count the fan blades going round. Slow Revving with plenty and plenty of GRUNT.
They where a little prone to cracking heads but that usaully comes down to the operator and cooling system care.
Alot of parts are still avalible from cat which is handy.
Old Magnets horsepower fiqure is correct.
All the best with her
Billy
Sun, Jul 26, 2009 2:46 PM
SJ
Send a private message to SJ
Reply to Billy-:
Billy
They also had an oil clutch rather than a dry one which helped the life of things in the clutch.Yes indeed they had a completely new D339 engine in them and about the only thing carried over from the old 3Ts D8800 engine were the size of the bore and stroke.
Sun, Jul 26, 2009 5:42 PM
chriscokid
Reply to SJ:
thanks,
Again the wealth of info from the members here is worth its weight in gold.
Now all I have to do is see if i can get it at a great price.
Sun, Jul 26, 2009 8:29 PM
Reply to chriscokid:
thanks,
Hi Bruce,
There seems to be a problem with both those spec sheets🙄 🙄
All the 17A's are oil clutch and although the engine displacement is the same the bible (rack setting charts) is quite clear on the horsepower ratings.
Don't see how they can use the same Nebraska test as the one is dated 1940 and the 17A came out in 1954.
Also on production I show the 17A ending in 1961 and the 47/48A coming out in 1962.
Per parts book on this serial number unit the operating weight is given as 26,930 lbs.
Sorry, I don't seem to own a correct spec sheet for the 17A either although I have all the related manuals.
Sun, Jul 26, 2009 9:28 PM
Billy-
Hi Bruce,
I dont think there ever was a nebraka test for a 3T. They only have one for a 7M.
There where 2 Nebraska test for the D7 17A. One for the C series and one for the D series.
Mon, Jul 27, 2009 5:04 AM
catskinner
Reply to Billy-:
My book shows for D7 17A 9921 built 1958, 9150-12132. First 17A built in 1954, I don't see how the NE rest could be for the 17A series. catskinner
Tue, Jul 28, 2009 9:01 AM
Snopro99
Send a private message to Snopro99
Reply to catskinner:
Hi , new to this site and hard to navigate. I also have a cat I just acquired , sn-17a4393 series c.
Im looking for info on this unit . It used to be my grandpas and now it’s mine, I never was shown how to use this machine. He had a D8 with pony motor I helped start that machine but along time ago, So here I am trying to start this without a manual and have no idea how to. The nice thing is this has electric start which will be much easier I assume. But I don’t know the proper procedures. Any advice would be greatly appreciated. Main issues for me are, throttle lever-start/run lever -flywheel clutch lever(locations)[attachment=59595]05090898-9EAD-49DB-9EAB-9C3825E806AF.jpg[/attachment]
Fri, Jul 3, 2020 10:03 AM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
