Looking for a D2 Carburetor Kit Diagram
Showing 1 to 6 of 6 results
novavalleycat
Send a private message to novavalleycat
I'm wondering if someone out there might be able to scan a picture of the Cat 10 carburetor kit and the carburetor apart to show me where the gaskets go.
I have one gasket that I can't figure out where it goes. It's a rubberized cork ring gasket about as big as a quarter.
Thanks for the help.
Jim Legge
in Nova Scotia
Wed, Jun 24, 2009 6:34 AM
Sasquatch
My scanner's broken at the moment, but I'm guessing the gasket you're talking about may be the one between the float bowl assembly and carburetor body? It's about that size and has a couple of semi-circular slots inside with a through hole in the middle, and two "ears" on the outside 180 degrees apart. That's my best guess.😊
Wed, Jun 24, 2009 9:58 AM
Reply to Sasquatch:
What Cat number carb are you working on?
Wed, Jun 24, 2009 11:57 AM
novavalleycat
This is for a T585 Ensign carburetor for my Cat10. The gasket is exactly the same size as the one that has the three holes in it. It's the size of a quarter and you can fit a dime through the inside of it.
Thanks again for the help.
Jim Legge
Thu, Jun 25, 2009 7:31 AM
novavalleycat
Reply to novavalleycat:
Jim Legge
I mistakenly said I was looking for a diagram for the D2, I'm actually looking for a carburetor diagram for a Cat10. If anyone could help, I'd really appreciate it.
Thanks,
Jim
Sat, Jul 4, 2009 1:00 AM
Thanks,
Jim
Hi Jim,
scan below.
Sat, Jul 4, 2009 6:39 AM
novavalleycat
Reply to edb:
Hi Jim,
scan below.
Thanks so much for the scan, that's great.
Jim
Sun, Jul 5, 2009 9:55 AM
