D6 9U What Size Wrench for Oil Drain Plug?
D6JP
Send a private message to D6JP
Can someone tell me what size wrench is needed to get the oil drain pluz out?
Mon, Jun 8, 2009 10:46 PM
Woody
Send a private message to Woody
If the tractor did not have one with it when you got it, you can make one from a 7/8 or one inch bolt. Weld a nut to the nut the other end of the bolt and use a standard rachet socket set up. Stick the bolt head up into the inverted hex shape to size it properly. You will need one of these for the hydraulic booster pump plug, plus your final drive fill plugs use a simlar configuration.
The plug is an inverted hex shape, you could also get one from your local cat dealer that fits a standard 1/2" drive ratchet, and has two sizes on it. 😊 Good luck, its a big plug so have an appropraite sized bucket for the oil when it comes out.
Mon, Jun 8, 2009 11:52 PM
Kelly
Reply to Woody:
Woody , you can also make one or two using an old broken socket.
Kelly
Tue, Jun 9, 2009 1:56 AM
SJ
Send a private message to SJ
Reply to Kelly:
Kelly
Even working for the dealer and them having one in the tool crib I made mine out a bolt and nut welded to it so I didn,t have to keep running to the crib for it.With the plug being molded sometimes the bolt head wouldn,t go in the hex hole right so just a little grinding on the edges of the head lets it slip in all of the plug holes good.
Tue, Jun 9, 2009 5:45 AM
Woody
Reply to SJ:
Kelly, using the old socket and welding the appropriate size bolt head is another creative idea for a plug removal tool.
D6JP if your tractor has a belly pan or rock guard on it you will need an extension to get up through the hole in the belly pan to get to the plug. As I recall an 8" or 10" extension should work.
D6JP if this is your first time changing the oil make sure you open the vent for the oil cooler when you to refill the tractor. If you have the service-mans reference book if will show you where its located, etc. 😊
Tue, Jun 9, 2009 10:00 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
