Horsepower comparrison
Showing 1 to 10 of 31 results
gauntjoh
Librarian
I've been wondering how or if the HP of some of our old machines can be compared to more modern machines.
My D7 7M for example is rated at 80 Drawbar HP, the engine, presumably has a higer HP because of losses in the transmission etc.
Does anyone know what the rated engine HP of my D7 (7M 1962) would be ?
Would this be directly comparable to engine HP quoted for modern day machines ?
Sat, Jun 6, 2009 3:58 PM
Thank you received: 21
Hi, Gauntjoh.
I am open to correction here but it was my understanding that back in 'pre-history', a rough guide was that drawbar hp would be approximately 75% of the flywheel hp of the engine. The lower figure was due to losses through the transmission, differential, final drives, etc..
If my memory serves me correctly, the formula for working our rated hp was:
bore X stroke X No of cylinders X RPM
33,000
For more info., see Wikipedia: http://en.wikipedia.org/wiki/Horsepower
Make yourself a sandwich before you read the above.
Then along came things like super-chargers and turbo-chargers and aftercoolers, torque converters and power-shift transmissions, electronic injection and variable valve timing, etc., and the rated hp figure became somewhat meaningless.
Hope this helps.
Sat, Jun 6, 2009 6:20 PM
OzDozer
Hi, Gauntjoh.
33,000
Hope this helps.
Horsepower is a measured, calculated amount of power, produced within a certain time. To be precise, it's 33,000 ft lbs/minute.
The difference between old tractors and new tractors is torque and reciprocating mass. Newer engines run a lot less mass, and produce power at higher RPM. Thus, maximum torque figures are lower. They can do the same amount of work as older tractors, but at higher engine speeds. They need to keep up RPM to produce the HP.
The heavier reciprocating mass of older engines means they "lug" more strongly than newer engines, and have a higher torque rise.
Thus they "feel" like they have more power.
Older tractors have higher friction losses, compared to newer designs, that have lower-friction components. This assists in getting more power to the ground.
The 7M has a tested Belt HP of 92.84, and a tested DBHP of 80.44. AFAIK, no Flywheel HP rating was ever stated for the 7M tractor.
Sat, Jun 6, 2009 7:20 PM
SJ
Send a private message to SJ
Reply to OzDozer:
I have my rack setting book from Cat that I used at the dealer for dyno testing and it says the D7 7M is 98 brake HP and 93 belt HP and is from the Cat form # 30782-1 instruction book.The settings are at 1000 RPMs full load.
Sat, Jun 6, 2009 7:39 PM
On a late D4 7U I believe its 63 flywheel HP and 54 DBHP.
Sat, Jun 6, 2009 7:57 PM
gwhdiesel75
Reply to SJ:
If an engine has a higher rpm to generate larger hp, wouldn't that mean that it will wear out faster? Haven't we traded higher hp for greater wear? I know my Best Sixty (and the Cat Sixties) had an rpm tops of around 600 (or was it 850?), but at idle, you can hear each cylinder fire - a wonderful sound!
I enjoy reading the technical things as above, and learn a lot from the folks who post. Thanks a bunch.
GWH
Sat, Jun 6, 2009 8:03 PM
biggastractor
Reply to gwhdiesel75:
GWH
Interesting thread guys. If you go back even a little further (the twenties)most of the machines in the Nebraska Farm Tests were rated twofold. One rating for drawbar and one for the belt. The difference was usually half. Thus a 30-60 Rumely would be 30 drawbar HP and 60 Belt HP. I assume the Holts and Bests were rated the same way but I didn't take the time to go looking for those figures.
Good Luck
Biggastractor
Sat, Jun 6, 2009 8:51 PM
tanker
Send a private message to tanker
GWH
[quote="gwhdiesel75"]If an engine has a higher rpm to generate larger hp, wouldn't that mean that it will wear out faster? Haven't we traded higher hp for greater wear?
GWH[/quote] The newer high speed engs are built w/ lighter internals{rods/pistons } so they don't seem to wear out any quicker ---but--- the high speed eng traded off fuel economy for rpm- on sawmill D13000 uses aprox 1&1/2 gal/hr while cummins on same blade uses 6-- RD7 used bout 2 gal/hr rooting trees & my 977 used 8 & it used 6 loading logs. made me cringe every time I started it up when diesel was relatively cheap..
Sat, Jun 6, 2009 9:34 PM
tanker
Reply to OzDozer:
[QUOTE=OzDozer;39575]Horsepower is a measured, calculated amount of power, produced within a certain time.
Torque vs HP can be very misleading- old racer saying-- HP is for going fast & torque is for pulling stumps--- some drag racers & truck pullers find this out by experience- some salt flat guys find it out the hard way....as one of them told me as we were discussing the subject "dynos don't have wheels"-- also dynos don't have tracks..side note-- had a chart w/ drawbar pull on my 2U-- WHEN THE 1200RPM ENG WAS LUGGED DOWN TO 800 RPM THE DRAWBAR PULL ALMOST DUBLED--[had warning not to operate in this mode for long periods of time]-as near as I could figure it just let the gov open up the pump--so HP ratings probably not reflecting this- don't know if othe cats do this or not??
Sat, Jun 6, 2009 9:46 PM
bob
Send a private message to bob
Reply to tanker:
A dyno doesn't need wheels or tracks. It's to test the performance of an engine that will power something with wheels or tracks. Horsepower is basically the rate of ability to do work or Force times Distance divided by Time. What the old racers were really trying to say was Stump pullers need the Force they want the Distance but it still comes down to Horsepower.
Later Bob
Sat, Jun 6, 2009 10:38 PM
Reply to bob:
Later Bob
My 1960 Rack Setting Manual states for the:
D7-7M1-up, 4T1-up, 6T1-up and 2T1-3T35309
is 98 brake horse power w/fan and footnote #14 states 81 draw bar horse power and 87 belt horse power.
The D4-7U, sr.# 37285-up lists only brake horse power w/fan at 60.5.
I consider the rack setting manual to be the only reliable source.
Sun, Jun 7, 2009 12:01 AM
| Hartley - South Australia
