D2 Generator information.
Showing 1 to 10 of 12 results
Cysco
I need some help in identifying the generator on my 1956 D2 5U. I have a couple pictures and the numbers on the plate are Delco Remy 1102734 6C26. The only thing is the "C" could be a "D". Also you can see what is left of the regulator. I don't know how much trouble it is to get a new regulator but my plans are to eventually take the generator off and let a nearby shop check the generator. I am assuming about the only thing the generator was good for was the lights.
Sat, May 30, 2009 8:45 AM
josh
1102734 crosses to 8f3333, 6V, 19A, CW rotation, used on D2 and other Applications for both lighting, and pony electric starting groups.
Sat, May 30, 2009 9:44 AM
Sasquatch
Reply to josh:
My old Delco-Remy book lists the Delco-Remy regulator #1118873 to be used on the 1102734 generator under the Caterpillar 1954-1958 application section. Unfortunately I can't find any specs for this regulator number, and it's so old it might be difficult to cross to a newer model. Hopefully someone else has some better specs.😊
Sat, May 30, 2009 10:05 AM
SJ
Send a private message to SJ
Reply to Sasquatch:
I would think any the 6V regulators off the Cats would work ok.
Sat, May 30, 2009 6:12 PM
Reply to SJ:
I would bet that if your local shop is any good, they can find a suitable replacement for that regulator. A lot of old cars, trucks and other tractors used that same style.
Sat, May 30, 2009 6:28 PM
Cysco
Reply to drujinin:
Thanks for the info guys.....I have an electric start pony motor but it is using a 12 volt battery.....how would that work with a 6 volt generator ?
Sun, May 31, 2009 1:34 AM
Sasquatch
Reply to Cysco:
If it was mine I would get the numbers off the starter and see if it's a 6 or 12 volt model. A 6 volt starter will work with a 12 volt power supply, but you won't get much out of a 12 volt starter on a 6 volt system. If you are going to use the 6 volt generator you'll need a 6 volt starter and battery. Good clean and true armatures and brushes on both units and nice big battery cables to help the current get to the load and the 6 volt system will work great.
Sun, May 31, 2009 5:19 AM
the Farmer3
Send a private message to the Farmer3
Reply to Sasquatch:
I have used 8volt batteries in the older machines-they would crank the 6v starter over quicker and still charge with the 6v generator
Sun, May 31, 2009 7:46 AM
Dozerman51
Reply to the Farmer3:
The problem with using an 8-volt batttery is that I doubt that it will fit in the battery box of the older cats. The battery called for is a 6-volt group 1 type. The group 2 6-volt will not fit in the Battery box -too big. I would think that an 8-volt Battery is a group 2 Battery only. Could be wrong though.😊
Mon, Jun 1, 2009 5:03 AM
Dozerman51
Reply to Dozerman51:
Your Generator was manufactured on March(C) or April(D) 26th of 1956.😊
Mon, Jun 1, 2009 5:39 AM
Cysco
Toby....Here is the numbers off the starter motor on the pony....Delco Remy 11 094 6E9
The numbers were quite hard to read or maybe my eyes are getting older.... 😊
Mon, Jun 1, 2009 9:09 AM
