Cat D2 thermostat
Cat D2 thermostat
Showing 1 to 10 of 11 results
Cysco
I discovered actually 2 things related to the cooling system while taking the head off my D2. First there is no thermostat in the housing and second there is no "pressure relief spring,etc" under the radiator cap.
I will need some guidence on this as to whether this is okay or do I start the search for the missing parts.
Sun, May 3, 2009 7:31 PM
JasonPayneCrawlers
I have a cap😊
Sun, May 3, 2009 8:53 PM
Cysco
Reply to JasonPayneCrawlers:
I have a cap😊
Jason, I have the cap just missing the stuff underneath. Does it come as an assembly ?
Sun, May 3, 2009 9:04 PM
JasonPayneCrawlers
Reply to Cysco:
Not sure I think that I extra springs
Sun, May 3, 2009 9:07 PM
Cysco
Jason, Let me know as there is only the cap....no springs,seals ,etc
...Thanks, Bill
Sun, May 3, 2009 9:10 PM
TomP-TX
Send a private message to TomP-TX
Reply to Cysco:
...Thanks, Bill
Cysco, I just replaced the thermostat on my D2 this week. The original part number was a 4F7059 but changes to a 6F9467. There is a brass retainer that goes on top of the thermostat. I had to make a little puller out of a 3/8" bolt and a socket in order to remove it. I think the retainer is still available, but the late model tractors changed the housing and don't use a retainer. Here are some pics that might help. Tom
Sun, May 3, 2009 11:37 PM
josh
Thank you received: 6
Reply to TomP-TX:
Cysco,
Which style cap do you have? the later kind on the right has no spring just a brass plate and washer, the pressure relief assembly is part of the radaitor, not the cap.
Mon, May 4, 2009 12:09 AM
Cysco
Reply to josh:
Cysco,
Josh....I have the one on the right. It is solid brass and a stud from the cap screws into the radiator. There is also a small copper "shim" ,for a lack of a better word, that slides over where the stud from the cap screws in. No other seal,brass plate or washer. Do you have a picture ?
Mon, May 4, 2009 6:13 AM
Cysco
Reply to TomP-TX:
Thanks TomP...I will make note of the part number and get one.
Mon, May 4, 2009 6:14 AM
josh
Reply to Cysco:
Here is a pic of two, slightly different caps, both used on the late model D2 and similar vintage tractors/ power units, with the same engine, not much more than a big brass plate, a rubber seal and something to hold it together. The one on the left is a 5H4041 and the right is a 5M7591. On the one on the left, the little brass ring goes above the plate.
Mon, May 4, 2009 8:55 AM
2bluejon
Send a private message to 2bluejon
Reply to josh:
Does the part # you gave for the D2 will it work on bolth motors the D311 ans the D3400 thanks
Mon, May 4, 2009 10:57 AM
