d6 9u governor rebuild
Showing 1 to 6 of 6 results
dblaz18
Send a private message to dblaz18
I'm trying to figure out what parts wear and need replaced I know the spring and I checked with cat its discontued but what else in there needs replaced any help would be greatly appreciated thank you Dave
Tue, Mar 31, 2009 4:08 AM
bob
Send a private message to bob
A guy down in Mo. just did his governor, can't remember his handle maybe yellercat.
Later Bob
Tue, Mar 31, 2009 5:00 AM
SJ
Send a private message to SJ
Reply to bob:
Later Bob
Usually if it,s got lots of hours on it the weight rollers get flat spots on them and sometimes the pin in them and the weights themselves pins and bushings get worn and the bearing on the end of the shaft in there. It,s almost a seek and find just what parts are worn if your doing a complete overhaul. The best spring I found for them is a 5F 6413 and also other engines with the style gov. that uses that type spring.The idles, high and low will need to be checked esp. with a new spring.I have rebuilt a truck load of governors and that spring worked the best for power and found that out from one of our older engine mechanic.
Tue, Mar 31, 2009 5:29 AM
dblaz18
Reply to SJ:
No springs are available from cat anymore any suggestions where to find one
Tue, Mar 31, 2009 5:55 AM
Kelly
db1az18,
What is the Sn of your D6-9U?
Kelly
Tue, Mar 31, 2009 6:45 AM
dblaz18
Reply to Kelly:
db1az18,
Kelly
It is 9u12844
Tue, Mar 31, 2009 7:25 AM
jw45
Send a private message to jw45
Reply to dblaz18:
It is 9u12844
heavy quip
Tue, Mar 31, 2009 8:50 AM
| Hartley - South Australia
Newby Hall Tractor Fest
