Oil in Gas Cats?
Oil in Gas Cats?
Showing 1 to 10 of 14 results
Jason 10/D4
What will it hurt to run detergent oil in a gas motor? I can get nondetergent in quarts but no 5 gallon buckets so I figure if it dont hurt anything I'm going to run detergent 30w. Just wanted to see what you guys think. I also have deisel cats so I would only have to have one oil!!! Jason
Wed, Mar 4, 2009 4:31 AM
hicrop10
Jason,I was told by an old timer that in the gas tractor the newer type oil will ruin the main bearings.I know it a pain in the ass to use quarts but it better than replacing an engine.If i find it in 1 or 5 gallon pails I will let you know. MIke
Wed, Mar 4, 2009 6:28 AM
Jeremy Williams
Send a private message to Jeremy Williams
Reply to hicrop10:
Out here in SD, you can buy non detergent a gallon at a time i know at least, I'm not sure about 5 gal buckets. I have seen the gallons at Campbell's Supply if anyone has one of those nearby the brand is Harvest King I think, but not for sure. Runnings might have them too, but i'm not positive. Jeremy
Wed, Mar 4, 2009 8:05 AM
OzDozer
Reply to Jeremy Williams:
Jason - Don't run detergent oils in old gas cats. The detergent oils were first produced .. and have always been designed for, diesels .. where there is a massive increase in carbon, gums, varnishes, and other undesirable pollutants .. as compared to the relatively clean fuels such as gasoline.
The detergent is designed to dissolve large quantities of carbon, gum and varnishes, to keep the diesel engine internals clean.
Some detergent oils are aggressive enough to attack and etch babbitt bearing surfaces. Gasoline engines produce only relatively small amounts of pollutants, and don't need detergent oils.
Using detergent oils in old gas engines will lead to glazing of the cylinder bores, particularly under light load .. and the detergent will attack all current build-ups of beneficial carbon, such as on piston ring grooves and around seals .. that are currently assisting with sealing.
Thus, after a short period of detergent oil use, you'll find that oil consumption will increase, and leaks will appear, where there were none before.
Wed, Mar 4, 2009 8:51 AM
ol Grump
Reply to OzDozer:
If it's a brand new overhaul, you might get by with detergent oils. .but if it's an older engine with a few hours on it you'll get leaks in a short time. I can't say about taking bearings out with the detergent oil but any gunk/carbon will get cleaned out and seals will start leaking with probably a lot of the gunk getting into the bearings as well. Once that happens the only cure seems to be a complete engine rebuild. Trust me on that. .been there and done that many years ago with a flathead Ford V-8.
Wed, Mar 4, 2009 11:31 AM
Reply to ol Grump:
Sometimes your local Feed Mill carrys Motor Oil for the convienance of "One-Stop Shop" for the farmers.
Wed, Mar 4, 2009 6:46 PM
Jason 10/D4
Reply to drujinin:
Thanks Guys for the info am going to try and track down some non detergent in 5 gallon buckets and use the detergent oil for my diesel cats. Thanks again Jason
Wed, Mar 4, 2009 7:45 PM
rjh-md
Reply to Jason 10/D4:
Jason, tractor supply in westminster has non-detergent oil 30&40wt in 2gal jugs
Wed, Mar 4, 2009 8:27 PM
Jason 10/D4
Reply to rjh-md:
Thanks Russell they also have 30 wt in 5 gallon buckets went thismorning so I know where to get it now. Thanks to all that replied. Jason
Sun, Mar 8, 2009 9:02 AM
bgates
Send a private message to bgates
How do you know if an oil is detergent or not?
I generally use Delo 400 in everything and I guess I don't know if it's detergent or not. I even use it in motorcycles and other small engines. I thought it was detergent.
I was told by a lifelong oil company chemist to use Delo or Shell Rotella in ALL engines. He says it's the toughest and best oil out there.
He said to use it in large, small, gas or diesel engines.
Sun, Mar 8, 2009 11:31 AM
Reply to bgates:
My 2 cents is that I haven't seen babbit bearings pitted up by Detergent oil. Either soft bearings "poured" or hard bearings "tinned" onto a backing plate (shell type).
My ASSUMPTION would be that something else in the system caused the bearing to fail. ie: accumulated gunk washed free by the detergent, old age, use and neglect, acids in the oil or even water (condensation).
Sun, Mar 8, 2009 7:30 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
