What would that have been used for?
Kevin
I was wondering about it use also. Seems pretty high off the ground.
Rich
Pushing cotton Bales around? Just a WAG😄
Coming from the Salinas Valley area it was probably used to push produce boxes (lettuce, celery, etc) up against a backing board for loading in rail cars, trucks or similar.
Also used to push field carts through the mud while doing the above harvesting.
I saw a photo of one used to push rail cars on a spur line into a factory building.
How so you start the 15? Do you have the rear crank setup?
Tom
[quote="Old Magnet"]Coming from the Salinas Valley area it was probably used to push produce boxes (lettuce, celery, etc) up against a backing board for loading in rail cars, trucks or similar.
Also used to push field carts through the mud while doing the above harvesting.[/quote]
That is how it was used in the Rio Grande Valley of South Texas in the vegetable fields.
This Push Plate was on a CAT 10 that was used on the docks of the Illinois River in Peoria. It starts from the front as it had a winch on the back. Bill
