Not a Cat, a Vaughn
Not a Cat, a Vaughn
Showing 1 to 10 of 14 results
bgates
Send a private message to bgates
This is my Vaughn Flex Tred Crawler. Steve Weaver wanted to see some pictures of it.
It runs great and works well, but is a bear to start.
I've been told some of these had long handles for walk behind and some had a seat, like this one. I don't know if this is a modification or if it's factory.
Does anyone know the correct paint scheme. There isn't much information on these. They were built by the Vaughn Tractor Company in Portland, Or. They are supposed to have made the engine and all components.
Tue, Feb 17, 2009 8:58 AM
n7gxz
Send a private message to n7gxz
Now what would one of those little things have been used for? Early form of a garden tractor?
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Tue, Feb 17, 2009 9:03 AM
bgates
Reply to n7gxz:
Kevin
Yes, they were used as a garden tractor on a 5, 10 or 15 acre garden. You could tow any implement behind it and switch them as needed.
I'm told it would replace a two horse team, but it seems to me it would replace one horse for plowing.
I haven't had a chance to really hook implements to it, but I'm hoping I can find some of the smaller ones and give it a try.
Tue, Feb 17, 2009 9:11 AM
deetwocat
Send a private message to deetwocat
Reply to bgates:
that is a neat machine you should be proud i like odd things like this i have afew oddball things when i bring them to a show it gets a lot of attention i am shure if you bring this to a show you will turn heads good luck.
Tue, Feb 17, 2009 10:25 AM
Mike Mahler
Send a private message to Mike Mahler
Reply to deetwocat:
I like it! Thats just too neat!
Mike
My services shown at www.myspace.com/vintageengine
Wed, Feb 18, 2009 12:45 AM
Thank you received: 14
Reply to Mike Mahler:
Mike
Hi, BGates.
You can find folks with a bit more knowledge about these jiggers than most on this forum at this site:
http://groups.yahoo.com/group/tracklayinggardentractors/
They seem a reasonable bunch of guys.
Hope this helps.
Wed, Feb 18, 2009 12:23 PM
Jim Sixty
Send a private message to Jim Sixty
Hi, BGates.
Hope this helps.
Nice looking little tractor, but just looking at it makes my shins hurt with those pointed wheels sticking out there. 😮 😮
Wed, Feb 18, 2009 8:32 PM
OzDozer
Reply to Jim Sixty:
Cute lil' jigger, and it appears it dates waa-ay back .. like 1924. I can't find any post-WW2 info on them .. and they don't even rate a mention even in my "oddball" tractor books, so they must not be around in anything more than very modest numbers.
Here's a guy on Smokestak with one, you might like to swap notes with him. His version has the walk-behind handles. Obviously, yours is the Ghia version, that came with the fully-sprung seat .. 😄
http://www.smokstak.com/forum/showthread.php?t=49957
Binderbooks has a copy of the care and operation manual for it for $8.95 ..
http://www.binderbooks.com/oldeng.htm
And here, in this following link .. it appears we have some of the history and origins of the Vaughan Motor Works and their products, which consisted mostly of drag saws, ice machines, machine shop jobbing, and production of the Flex Tred garden tractor .. I'd say its quite likely the little rigs production, didn't make it past WW2 .. 😞
Note that this item was written in 1928 ..
http://freepages.genealogy.rootsweb.ancestry.com/~jtenlen/ORBios/evaughan.txt
Wed, Feb 18, 2009 9:17 PM
Jed
Send a private message to Jed
Reply to OzDozer:
My father-in-law restored one a few years back. His was the walk behind version, however I think it had a two cylinder engine and was liquid cooled with an octagon, honeycomb type radiator. Very nice!
Thu, Feb 19, 2009 1:07 AM
sandman
Send a private message to sandman
Reply to Jed:
Here's a Vaughan rider I restored a few years ago. I took it to the ag show in Tulare Ca., due alot of attention. I added a v-belt pully so it could be started with an old ford starter. Steered like a Bobcat, that is one track could rotate foreward and the other could rotate in reverse making it turn in it's own axis. I added the mini orchard fenders. Karl
Thu, Feb 19, 2009 8:58 AM
bgates
Reply to OzDozer:
[quote="OzDozer"]Cute lil' jigger, and it appears it dates waa-ay back .. like 1924. I can't find any post-WW2 info on them .. and they don't even rate a mention even my "oddball" tractor books, so they must not be around in anything more than very modest numbers.
http://freepages.genealogy.rootsweb.ancestry.com/~jtenlen/ORBios/evaughan.txt[/quote]
OzDozer:
Thank you so much for that information. I ordered the little manual and it did give me some good info. I got that last year.
The two links you gave me were great.
You are always so considerate and helpful with really good information I hope to meet you some day and shake your hand.
You are a very important piece of this website.
thank you again,
Bruce
Thu, Feb 19, 2009 9:33 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
