Anyone have a Cat 12 8T with electric start?
raklet
Send a private message to raklet
Has anyone converted a Cat 12 8T to electric start or acquired one that already has it installed?
I want to convert my grader to electric start but I need measurements on where to locate the holes that I need to cut into the starter boss on the bell housing.
Sat, Feb 7, 2009 11:07 AM
josh
Thank you received: 6
I have a late model 8t parts machine that has both the cut out for an electric starter and the hydraulic side shift for the blade, call me if you want information.
Josh
707 937 5633
Sat, Feb 7, 2009 12:20 PM
raklet
Reply to josh:
Josh
707 937 5633
I put up some more pictures of my starter boss and some dimensions here
http://www.acmocbb.org/ACMOC_BB/showpost.php?p=33456&postcount=10
Thanks,
Tyler
Tue, Feb 10, 2009 9:16 AM
933scotty
Send a private message to 933scotty
Reply to raklet:
Thanks,
Tyler
We just converted our 12 to elec start we got a starter off of a 318 gen set and just bolted it on. We put the batts in the rear tool box and added a solinoid switch. We still need to update the generator to 24 volt in the spring Good luck Scotty
Fri, Feb 20, 2009 7:25 AM
raklet
Reply to 933scotty:
Wish I had it that easy. I don't have holes pre drilled for bolting on. I have to drill my own holes in the bell housing.
I have a starter on order. I'm going to convert to an alternator instead of a generator.
The rear tool box isn't a bad idea for batteries. I think I'm going to tear the pony motor off and put the batteries there though.
Fri, Feb 20, 2009 8:38 AM
