D-4 78a final drive
D-4 78a final drive
Showing 1 to 10 of 25 results
cowboyofequipment
Send a private message to cowboyofequipment
😮 D4 78A HELP!!!!!!!!!!!!!! I need to find a bull gear or final drive about what is the cost and does anyone have one??? Transmissione Sir # is 4K5035
Will 7U final dirves work or is there a cross? Can anyone help with my questions?
Thanks, Chris
Wed, Jan 21, 2009 6:28 AM
jaker65
Send a private message to jaker65
well once again chris, if it is the same as a 7u i got the part for you. already out and ready to go, final drives and etc. if someone can confirm this, he will one his way in no time. if it is for the dozer i saw of yours, then i am guessing yes it will work. another trip to ohio might be in my future.
Wed, Jan 21, 2009 7:12 AM
Thank you received: 60
Reply to jaker65:
From my aftermarket interchange info that is a "no go" with 7U
You need a 4K4632 gear.
Fits 39A, 40A, 78A, 20J, 83J1-3259, 84J
The matching pinion is a 9H6980
Wed, Jan 21, 2009 7:32 AM
jaker65
maybe someone can fill me in better on this one. i am a little confused as to where this part is on the machine that he is looking for.
Wed, Jan 21, 2009 7:38 AM
cowboyofequipment
Reply to jaker65:
JAKE my dad is looking at a d 4 78 a a little newer than my d 4 7u it needs a bull gear. I guess i am trying to get an idea on how much to fix it. I shure was hoping that your parts would cross. Did you get the lincon welder fixed? I bought a contintal engine manual on ebay. Do you still need one?
Wed, Jan 21, 2009 7:49 AM
Reply to cowboyofequipment:
My mistake...I was thinking bevel gear not final drive bull gear😮 😮
Let me get back on that one.
OK, similar situation, "no go" on D47U
Different bull gear number is 7K4458
Fits 39A, 40A, D4C's
Fits 78A, 22C, 20J, 82J1-3237, 83J1-1800, 84J1-1382, D4D's
Can't help you with cost but shouldn't be to hard to find used.
Matching final drive pinion is a 7K4512 if you need one.
Wed, Jan 21, 2009 9:00 AM
OzDozer
jaker65 - The bull gear is the very large gear inside the housing (ham case) that is behind the sprocket. This is the very last gear in the drive train, and is bolted to the sprocket shaft.
This gear is driven by a much smaller pinion that is located at the top forward part of the housing, and which is attached to, and driven from, the steering clutches.
As a result, these parts are known as the final drive pinion, and the final drive bull gear.
Wed, Jan 21, 2009 9:57 AM
jaker65
Reply to OzDozer:
thank you Oz dozer! that makes it 10 times easier on me. I am sorry i do not have the part chris, i was hoping i did. i didnt get the welder fixed yet, the seal i bought is just too big. i am probably looking at pulling the crankshaft to repair the rear seal. If you do have the manual on it, that would a big help for me! hope to get to come down again sometime soon. I still havent got to that radiator yet. the weather just been so cold around here, that i would freeze my hands to the unit.
Thu, Jan 22, 2009 12:42 AM
SJ
Send a private message to SJ
Reply to jaker65:
Chris, give this place a call and is in western Pa. and is Cleveland Bros. used Cat parts store.The # is (724) 325-9478 and ask for Den Tressler if he,s available when you call.Get the parts numbers ready so to save time.
Thu, Jan 22, 2009 1:05 AM
English Al
Send a private message to English Al
Reply to SJ:
Chris - I think the part #s you are looking for are
6K1022 gear and 5K1022 pinion. But I think those numbers
change to heavier gearing. Cat Product Bulletin Ma 20 -1972
Sorry can't help on prices Cheers Al
Thu, Jan 22, 2009 3:03 AM
D4D83J
Send a private message to D4D83J
Reply to English Al:
Hi Chris. I've got your parts, 970 270 8771
Sun, Jan 25, 2009 10:40 AM
