R designation
R designation
Omnitrac
Send a private message to Omnitrac
When Cat went from the R4 to the RD4 why did they keep the R, what did the R mean at that time. Anyone know?
Dennis Wilkinson
Sun, Jan 18, 2009 9:32 PM
bernie
I found a couple posts at ACME. I thought there was one more either here or there with more info from OzDozer....
http://www.antiquecaterpillar.net/ACF_v2/showthread.php?t=331&highlight=RD4
http://www.antiquecaterpillar.net/ACF_v2/showthread.php?t=12317&highlight=RD4
bernie
Sun, Jan 18, 2009 11:16 PM
Willie
Reply to bernie:
bernie
Well first off they went from RD4 to R4 they put a Diesel engine in a 6G-30 and called it the RD4. In 1935 they came out with new style 30 using the ser.no. 6G.
1935- 6G-30 new version of the Thirty
1936- RD4 Diesel engine put in a 6G-30
1937- D4 The R was dropped and called the D4
1938- R4 The 6g-30 was changed to the R4
They all used the basic 6G drive train and under carraige.
I was always told the RD was used because the used the Rudolff Diesel design in the second atempt on diesel engines.
As for the R is was first used in 1934 when the took a 22 and added track frame weights and changed the brass rad. badge and became the R2
Sun, Jan 18, 2009 11:53 PM
OzDozer
Reply to Willie:
Bernie - Below is a virtual copy of my post from ACME. This version I have supplied is taken verbatim from Henry Howards (VP of Caterpillar Sales in the 1930's) historical discussions with author Randy Leffingwell .. and I believe this is as close as anyone gets to the story behind the "R" designation of the "RD" series Cats ..
[color=Blue]"In the period from late 1931 to late 1937 Caterpillar went through a lot of upheaval with a lot of rapid changes .. from the release of the Cat Diesel, to major color change, to nomenclature changes, and a host of new, totally redesigned models.
In 1934, there was an argument put forward by salespeople, led by Henry Howard, Cat VP of sales .. that the nomenclature of Cats had to change from the likes of Sixty, Thirty, 2 Ton, etc. .. which were originally designed to represent HP and weight ratings .. to something more obscure, that didn't really relate to anything.
The problem salespeople had been having in previous years, was that with development, tractors were no longer the HP, or weight, they were originally allocated.
After a considerable amount of heated discussion, it was suggested by Claude Heacock, Cat President, at a meeting, that a new tractor, yet to be named (it became the R5) be named the 'Roosevelt 50' .. !
This appalled the sales people present, in that, it was known that Heacock had a great hatred for President Roosevelt and his Depression policies .. and made no secret of it .. to the extent it had been affecting sales in some areas!
It appears that Heacock had, in a fit of perversity, decided that Roosevelt was a good name, as it meant nothing to him!
The idea was shouted down .. and letters and numbers were discussed .. with the basic ideas of a letter for gas tractors, and another letter for diesels becoming the nomenclature .. as well as the basic size groups, of 4, 6, 7 and 8 ..
Heacock handed down a decision, that from early 1935, gas Cats were to be prefixed with 'R', and diesels with 'RD' .. with the size number behind the 'R' and 'RD'.
This policy was carried out on an ad-hoc basis, as the RD-8 had already been named the '80', and name plates cast with that number .. but they were hurriedly ground off, and replaced with RD-8.
The R4 was released in 1934 with the Thirty name .. and against all stated policy, it stayed the Thirty until 1938, when it finally became the R4.
The diesel engined R4 was released in early 1936 as the RD-4, and the 'R' was dropped from all diesel models in 1937.
No-one knows for sure, except Claude Heacock, why the 'R' in the nomenclature was chosen.
It has been reported that the 'RD' stood for Rudolph Diesel .. who was the original designer of the diesel principle .. but it has also been suggested the link is fanciful, as there was no real tie-up between Rudolph Diesel and Cat, seeing as Diesel died in 1913 under mysterious circumstances.
It has also been suggested the 'RD' stood for Rosen Diesel, as Arthur Rosen was the brilliant young Cat Diesel engineer who first proposed that Cat build their own diesel engine .. as far back as 1923 he contacted Pliny Holt with the proposal .. but it was 1925 before he got a job at Cat, and it was 1927 before he went to work on the design of the Cat diesel, using a Daimler Benz and 4 other current diesels as start point designs.
The largely Arthur Rosen-design Cat Diesel, released in 1931, was an immediate success, and Rosen became a celebrity, producing over a dozen research technical papers on Diesels between 1932 and 1935.
He was also responsible for working with Standard Oil lubrication engineers to produce the first detergent engine oils (Delo), to overcome the serious oil burning, ring sticking and gumming that nearly killed the early diesel sales.
As I have said .. no-one knows, except Claude Heacock, why R, RD and D were the chosen letters .. but it sure produces some conjecture .. and the reasons have been forever lost with him, as he is now long dead."[/color]
The ACME thread link is here .. http://www.antiquecaterpillar.net/ACF_v2/showthread.php?t=335&highlight=roosevelt
Mon, Jan 19, 2009 7:39 AM
| Hartley - South Australia
