Tractor-Operated LeTourneau Crane M20.
Showing 1 to 9 of 9 results
boely
Send a private message to boely
Hello to you all and I wish al of you an verry good and healthy 2009😊 !
I have an question,I am searching for picture,s and/or scaledrawings of the Tractor-Operated LeTourenau Crane M20 as used by the US Corps of Engineers in WW2.
I have one picture in my book The Corps of Engineers-Troops and Equipment- I would like to scratchbuild an 1/35 scalemodel of this crane.
So my question is if you could please help me in finding reference,s on this crane,any help is much appriciated.
If there are picture,s and/or scaledrawings of this M20 Crane that is,I have done an searche on the net and could not find much about this crane.
Thank you for any help and greetz from the Netherlands!
Boely.
Sat, Jan 10, 2009 9:23 PM
OzDozer
Hello Boely - I don't have much, but here is the sales specification sheet, and the line drawing, from the 1943 LeTourneau sales catalog.
The drawing should be to scale .. but unfortunately, there is no reference such as the scale, or a graph .. and the drawing is done on a three-quarter view basis, making it even more difficult to relate to precise measurements. I trust this helps you some. Regards, Ron.
Spec sheet .. http://img440.imageshack.us/img440/8712/letm201fj9.jpg
Line drawing .. http://img440.imageshack.us/img440/1167/letm202uo4.jpg
Sun, Jan 11, 2009 7:08 AM
QuAD
Reply to OzDozer:
Have only some pics from 1937 but maybe help it anyway.
[img]http://img152.imageshack.us/img152/8676/letcw7.jpg[/img]
Sun, Jan 11, 2009 9:08 PM
boely
Reply to QuAD:
Thanks!!
This will certainly be of help,OzDozer and QuAD many thank for the reference,s as said they are of great help.
The line drawing and the picture from 1937 are great,the picture shows some great details!!
Again thank you both for your help.
Grtz!
Boely.
Sun, Jan 11, 2009 11:25 PM
OzDozer
Reply to boely:
Thanks!!
Grtz!
Boely.
The crane in QuAD's picture is not an M20 .. but appears to be an early version of the AD-4. This unit was available with either steel wheels or rubber tires.
The steel wheel option appears to have disappeared by the early 1940's, probably due to the need for speedy movement from site to site. The steel wheels limited the crane to site use.
In 1940, the range consisted of the AD2, AD3, and AD4 .. but by 1943, with additional cranes built purely to Military specifications, the range consisted of models AD2, AD3, AD4, L20, B30, L41, M20, TC4, and L40.
Mon, Jan 12, 2009 10:35 AM
§wishy
Send a private message to §wishy
Reply to OzDozer:
[b]Boely
Ifn U still Lookn try these on for size
LeTourneau patents just a clik away
LOL
http://www.google.com/patents?id=UnVRAAAAEBAJ&dq=letourneau+crane
http://www.google.com/patents?id=JwtHAAAAEBAJ&pg=PA1&dq=letourneau+crane&source=gbs_selected_pages&cad=0_1#PPA2,M1
http://www.google.com/patents?id=SulHAAAAEBAJ&pg=PA1&dq=letourneau+crane&source=gbs_selected_pages&cad=0_1#PPA1,M1
cya
§wishy
HasBeen[/b]
Artist&PixelMaNipple8R
[CENTER]🙄 - : [B]ButEyeDoSt&2BCorrected : - 😛
Ifn U Get my Drift[/b]
😮 [/CENTER]
Mon, Jan 12, 2009 12:17 PM
OzDozer
Swishy - All those patents are purely for the LeTourneau tractor unit cranes .. those fitted up with a permanent LeTourneau tractor unit .. not the towed crane design as in the M20. These towed tractor cranes were designed to be used behind dozers, utilising the tractor drawbar and the tractor CCU.
The ones with rubber tires could be lowered right down, and then roaded at speed behind any truck of sufficient size, thus making them extremely portable and very versatile. The lifting capacity of these style of cranes was nothing short of amazing, for the era.
Tue, Jan 13, 2009 9:23 AM
AJ.
Send a private message to AJ.
Reply to OzDozer:
Found a picture of one on rubber as used by AAF WWII
AJ
Tue, Jan 13, 2009 11:19 PM
8D-132
Send a private message to 8D-132
Reply to AJ.:
AJ
LeTourneau crane?
Wed, Jan 14, 2009 10:43 AM
OzDozer
Reply to 8D-132:
LeTourneau crane?
8C-132 - Your pic is a thumbnail that cannot be enlarged, it needs to be posted full size. However, what you have pictured, most definitely appears to be an M20 model, LeTourneau towed crane.
The term "tractor unit crane" is the term usually reserved for the LeTourneau cranes that were permannetly fitted up with a LeTourneau Tournapull tractor.
Wed, Jan 14, 2009 2:50 PM
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
