cylinder head inprovement using 14mm plugs
Thank you received: 44
15 years 11 months ago #24767
by Steve A
For those of you that are interested I made a small change /repair /improvement to my 7c15. This tractor sat for 28 years with no spark plugs in it, one of the original sparkplug holes had no threads left and the other 3 were not much better.with the original size plugs the electrode dident protrude into the coubustion chamber and seemed to have some issues with foweling. I made bushings to use a 14 mm plug with a longer reach. This puts the electrode in the combustion chamber like a modern engine.
The plug I got for it is a Autolight 3926, not as hot as the 3077 but I am thinking it will work out better in the combustion chamber, Time will tell
Thank you received: 6
15 years 11 months ago #24771
by ol Grump
That looks good the way it is. I'd be using the coldest plug first, checking the color of 'em and sloowly working up. Sparkling plugs are a lot cheaper'n pistons, that's for sure. I've often thought about making adapters to change from the 14mm x 5/8" reach plugs in pony engines to sumpin' that was a bit more common.
At any rate, I'd say you were on the right track. . . just watch the color of the plugs carefully.
Time to create page: 0.119 seconds
