Reply to greyhead:
I removed the floor panel to see what I was in for😕 O.M. I took the access plug out ,is it safe to say that the pinion dogs should be sharp and not rounded.
You said to remove pinion housing to service or did you mean pony unit as a whole?
And to ask two more questions,Is a direct start made for this engine (if i pull whole pony unit, might as well do a rebuild on it as it was the only thing we didn't work on last year) Where is the best spot to put a block heater? Thanks for all the replys.
Yes, the pinion latches should be sharp where they engage the stop.
Access on yours is either remove the top of the clutch cover or pull the whole pony motor assembly including the pinion assembly. Heck of a lot easier to work on it in the open.
Yes, there are specialty suppliers that offer direct start conversions.
Try C & C Battery
Corpus Christy, Tex
1-800-531-1038
They are one of the original conversion suppliers.
Gotta look at my stuff for the block heater connections
I'll edit this post later😊
Looked into mounting block heater.....challenge is to get circulation on both sides of the thermostats. Assuming you would use a tank type external heater you need high and low connections to get thermosiphon effect. Bottom connection candidates would be the plug fitting near the water pump inlet flange or the block drain (also pony water line connection to block if you go to direct start). Could also tap into lower radiator hose.
Top connection (for the block) would be the drain plug fitting on the bottom of the thermostat housing. A top connection to include the radiator circuit is a little more challenging as there are no available taps. You could either drill and tap the thermostat housing cover (later D339's had provision) or tap into the upper radiator hose to complete the circuit.
The tank heater (top) would require a tee or Y connection to supply both radiator and block circuits. This would become a by-pass around the thermostat when operating so you might want to install valves.
Input welcome!!!!
