Fan belt for a 22
Fan belt for a 22
Showing 1 to 10 of 12 results
WyoCat
Does anyone have a good part number for a fan belt for a 22?
Chad Enyeart
Tue, Dec 9, 2008 3:38 AM
Catmatt
Send a private message to Catmatt
If it is the same as 15, the 15 number is Gates TR 34456
Tue, Dec 9, 2008 4:31 AM
SJ
Send a private message to SJ
Reply to Catmatt:
Take that Gates part number to a place that sells Dayton (Dayco) belts and get a Dayton belt as we found them to be the best belt or were when I was working yet at the Cat dealer. Dayton at that time made belts for the Cat factory but don,t know if they do today yet.If we needed belts not furnished by Cat or for other applications we got the Dayton.
Tue, Dec 9, 2008 4:57 AM
Catmatt
Reply to SJ:
Chad,
The more I think about it, I think cat still makes the fan belt for caterpillar 22...Try to part number from the parts book.
Tue, Dec 9, 2008 5:05 AM
WyoCat
Reply to Catmatt:
Chad,
I was hoping to get a belt put on tonight. Does anyone know if the PV series 15 belt is the same as a 22?
Chad Enyeart
Tue, Dec 9, 2008 5:41 AM
chugwater crawlers
Reply to WyoCat:
Chad,
Cat belt for a twenty two is Cat part number 6B-1039-DF. They still make it.
NAPA number for a PV-15 is 25-24438. Appears to be thinner than the 22 belt
They look close, but I could not locate them when I took a quick look in the parts book so I cannot be sure.
Good luck!
Tue, Dec 9, 2008 6:31 AM
Jon
Send a private message to Jon
Reply to WyoCat:
the numbers I have are
cat #6B1039
GMC #2136721
Goodyear #32460
Gates #TR 34456
Tue, Dec 9, 2008 6:32 AM
chugwater crawlers
Reply to Jon:
cat #6B1039
GMC #2136721
Goodyear #32460
Gates #TR 34456
I found the old part number in the parts books for you. It is 2B463.
It shows the same part number fo the PV-15 and the twenty two belt.
Tue, Dec 9, 2008 7:11 AM
Eric Marshall
Send a private message to Eric Marshall
Reply to chugwater crawlers:
same belt as the D2
Tue, Dec 9, 2008 9:57 AM
bruce oz
Thank you received: 21
Reply to Eric Marshall:
same belt as the D2
hello ,the 6B1039
is the number from cat for the fan belt i used on the 22 i had ,its a bit tigth ,but fits ,bruce oz
Tue, Dec 9, 2008 4:18 PM
OzDozer
Reply to bruce oz:
hello ,the 6B1039
Chad - Well, you're in luck! .. it just so happens, that I have my 1937 Thermoid fanbelt catalog right here .. and the Thermoid P/N is V-98.
Now, if you just run down to your local Thermoid dealer .. I'm sure they'll have one on the shelf, ready and waiting for ya .. 😄 😄
http://img371.imageshack.us/img371/6120/thermoidfanbeltsym0.jpg
Seriously .. the good part about the catalog info is that it gives the precise dimensions of the fanbelt, right down to the angle of the belt wall .. and it also shows (if the catalog is correct) .. that the Ten, the Fifteen, the Twenty, and the Twenty two, all share the same fan belt .. 😊
Tue, Dec 9, 2008 7:37 PM
