Where you are located, and if you plan to run it during cold temperatures, I think a starting motor is still worthy of consideration. I believe you can mount an electric starter, I know someone with a '53 3T set up with direct start, someone here would have the details on the type, and how to mount it, you'll need batteries, and enough reserve to crank that diesel, enough to build up some heat in those cylinders, I'd seriously be thinking about a block heater or something similar, hard to figure if a battery reserve would be enough to crank that D8800 4 cyl enough to make enough heat with the compression lever on 1/2 or run. If the diesel has enough wear on it, less compression it will be harder to start in real cold temperatures, having enough battery reserve and wear on the electric starter come to mind. Something to consider, not sure if anyone can suggest some ideas for cold weather starting.
In my experience with one that has a good running diesel, without a lot of wear, good compression, electric starter will work great in warm weather, and probably down into the mid 40's, maybe a bit lower, still probably crank enough to do the job, but once you are in the teens, could be problematic. My 4T will fire effortlessly in summer weather, soon as you turn the compression lever to run and give it some throttle, it runs without any popping or smoke, but in cold temps, 20's and below, that starting motor earns it's keep, it has to spin that motor quite a bit, get that coolant warmed a bit, and oil pressure to register, and still, if you put compression to it to soon, it will bog right down, 24 HP motor, better to let it spin awhile longer, after it's warmed up a bit, it will start popping off and run. Just my own experience, hard to understand how an electric starter would perform in cold temperatures, 20's and below.
Starting engines are definitely a maintenance item, and there are some important things to know about them, but once you have it straightened out, they seem to run well enough to get the job done in some real cold temperatures, if you don't need to run in the cold, this might not be an issue, but beware, that D8800 does need to spin or be preheated somehow in the bitter cold temps, no way I can see, just moving the lever to compression and cranking it over with an electric starter, and it firing right up without having the block warmed up, glow plugs or some other means to pre-heat, I hate using ether.
