1942 tractor D8 serial 8R1344
wbp2
Send a private message to wbp2
Hi folks on the ACMOC,
I have bought the above tractor, and it is great condition, with almost new undercarriage. I would love to find out who owned it first: military, or private individual. I detect some military green left on the tractor.
Does anyone know how many of the 9999 D8's produced as 8R were sent to the military?
Best wishes, Will
Thu, Nov 27, 2008 2:37 AM
MARTYN WILLIAMS
Hello Will
A mate of mine is restoring a D8R .
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Thu, Nov 27, 2008 2:49 AM
Billy D7 4T
Send a private message to Billy D7 4T
Reply to MARTYN WILLIAMS:
Hello Will
Martyn
War Department Purchase order #C-4504 & C-5206, correspond to the 8R series, according to the TM5-3054 manual. 8R's were built 1941-1945. Most likely a military tractor with that low of a serial number. War demands for tractors as well as the large civil projects going on at the same time, like the Alcan highway, in Alaska, you would think this one was definitely part of a government purchase order, especially being an early model.
Thu, Nov 27, 2008 9:50 AM
OzDozer
Reply to Billy D7 4T:
wbp2 - Your tractor is a mid-1942 year of production, and seeing as it has Olive Drab as its primary colour, it would almost certainly have been part of an early 1942 military purchase order .. a period when military purchase order numbers practically doubled monthly.
I seem to recall that all Cats coming off the production line were still being painted yellow for civilian use, and OD for military use, in mid-1942. I think it was late 1942, or early 1943, before all Cats came off the line, in OD only.
Once civilian purchase restrictions came into place, around early 1942, it was difficult for civilians to purchase tractors unless they could prove a critical need, or were engaged in vital war production work.
One of the first of a number of the "limitation orders" of the War Production Board, was a directive, on 19th Feb 1942 .. which prohibited the sale and delivery of track-laying tractors to individuals and organisations who had a preference rating below A-2.
Steel was in short supply in America in 1942. Until more steel plants could be put into production, even Caterpillar was on rations. For July of 1942, Cat ordered over 72,000 tons of steel, and received a little over 47,000 tons. D8 production was down 36% on projected production. It was a tough time to be a civilian looking for a new tractor.
The figures in the publication "Yellow Steel" quote that from early 1942, the military was taking 85% of Caterpillar tractors produced, and the remaining 15% were allocated to contractors for high priority war construction projects, or agricultural producers that were producing food for the military forces.
It was noted that from mid 1942 to late 1944, Caterpillar dealers had virtually no new tractors or Cat equipment to sell, due to the overwhelming demands of the military. The dealers survived by overhauling old tractors, and salvaging and reconditioning parts, that were previously considered to be good only for scrap.
There were only 342, 8R's produced in 1941 .. meaning that approximately 9650, 8R's were produced between Jan 1942 and early Dec 1945. The 2U series appeared in late Dec 1945.
Approximately 2500, 8R's were produced in 1945 .. but military tractor orders slowed appreciably in late 1944, and ceased abruptly in early August 1945.
On that basis, it wouldn't be unreasonable to assume that around 80% of the 8R's produced between Jan 1942 and Aug 1945 (approximately 8650 tractors) were military tractors .. making the total number of military 8R's probably a little under 7000 tractors.
Thu, Nov 27, 2008 4:31 PM
MARTYN WILLIAMS
Reply to OzDozer:
Some interesting information there. What about the D7's,and D4 7J's? and detailed info on them available?
Martyn
Aveling Barford GA
D2 3j
D4 7j Dozer
btd6 Drott X 3
B100
I H TD6
Fordson major
Fordson N
Hydrovane 90
Thu, Nov 27, 2008 7:14 PM
Billy D7 4T
Martyn
Same thing for the D7's, 7M being built 1940-1944, 9999 of those + 9999 4T's ordered, as well as the 3T production run commencing in '44, by the wars end, there were some surpluses of D7's, some of which were mothballed or not used like one of mine, until it finally was sold at a gov't auction around '70, it had no dozer blade on it, kind of slipped through the cracks but kept operational until surplused out, lot of layers of O.D. green under the yellow. The earlier than expected end of the war certainly changed things.
All this one had on it was the LeTourneau R7 PCU, a new 7A blade was added later by whomever bought it at auction, along with what I suspect to be a later hard nose, does not have the older style like other 4T's with the LeTourneau dozer kit and heavy duty radiator guard. Someone switched out the left fender, to the heavier style, I have the original, but after all these years, it's at 1015 hours, I've got some catching up to do on this one, always either a lack of time or money, but I do keep that motor turned at a least 1x per month, make sure it does not get seized like my other 4T yard ornament did while it sat where my fathers friend left it after borrowing same in the late 70's.
Thu, Nov 27, 2008 10:34 PM
