Best 60 SR#
Best 60 SR#
Omnitrac
Send a private message to Omnitrac
Does anyone have a list serial numbers for the Best 60 so year can be determined. Also does anyone know how many were built.
Dennis Wilkinson
Wed, Nov 19, 2008 9:30 PM
rustrunner
Send a private message to rustrunner
1919 101A-352A
1920 353A-993A
1021 994A-1056A
1922 1057A-1248A
1923 1249A-1684A
1924 1685A-2235A
1925 2236A-(something less than 2965A
Thu, Nov 20, 2008 6:09 AM
bruce oz
Thank you received: 19
Reply to rustrunner:
1919 101A-352A
1920 353A-993A
1021 994A-1056A
1922 1057A-1248A
1923 1249A-1684A
1924 1685A-2235A
hello Omnitrac ,around 18900 model 60 were built by best and caterpillar from 1919 to 1931 ,if you post the number we can tell you the yr if it not on the list above ,bruce oz
Thu, Nov 20, 2008 6:17 AM
Omnitrac
Reply to bruce oz:
The only number I can find is on the right side of the engine which has ENGINE 5470.
The right fender is missing so I assume that is where the tractor sr# was located.
Is there any way to determine a a tractor # using the engine #?
There is no numbers stamped into the frame up by the radiator.
Dennis
Sat, Nov 22, 2008 10:28 PM
YeLLoIrOn
Send a private message to YeLLoIrOn
Reply to Omnitrac:
Dennis
hey dennis im the guy that called you from okla. last weekend. i take it you finally got it home. Was wondering if you got the loose parts they said they supposedly had.
Caleb
Sat, Nov 22, 2008 11:36 PM
